O2 sensor help
Old Dec 9, 2006 | 05:30 AM
ken2830's Avatar
Default O2 sensor help
I have to extend my O2 sensor...what's the best way to do it???can I use regular 10 12 gauge wires??
Old Dec 9, 2006 | 09:03 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: O2 sensor help (ken2830)
is it 1 or 4 wire?
Old Dec 9, 2006 | 09:38 AM
ken2830's Avatar
Default Re: O2 sensor help (HondaPartsHero)
its a 4 wire...
Old Dec 9, 2006 | 09:49 AM
Relic1's Avatar
depends on how far. if it's less than a foot you'll be fine with normal 16awg wire.
if it's more than that I'd use shielded wire for the O2 signal part of it.
Old Dec 9, 2006 | 10:09 AM
ken2830's Avatar
Default Re: (Relic1)
its more than a foot..I had swapped in an H22 and the bung for the O2 sensor is on the downpipe on the header compared to the single cam wich is on the top of the manifold..so I just need to extend it that far...
Old Dec 10, 2006 | 12:07 PM
Technical Hero
Default Re: (ken2830)
just use 16 gauge wire shielded or buy an extension harness
Old Dec 10, 2006 | 04:07 PM
Relic1's Avatar
you can pull the wires out of the loom and they will reach with no problem...
Without going that way... the extension harness is the easiest way to go.
DIY version...
the white wire has to be shielded, mic wire from Radioshat works great. Connect the shield to the existing shield. The other three wires can be extended with simple 16awg wire.
Old Dec 11, 2006 | 09:58 AM
E-Money's Avatar
if he extends it, wont that add more resistance, and if i heard right, they work by resistance.
Old Dec 11, 2006 | 01:04 PM
Relic1's Avatar
the O2 sensor is:
a 0-1V signal
ground for the O2 signal is ground.
power for the O2 heater
Control for O2 heater from ECU
As long as you're not using wire nuts and house wiring you'll be fine. The only sensors that are critical about lengthening are the distributor signals, and even they are workable.
kevinoneill
Dec 25, 2010 01:05 PM
92nahatch
Jan 28, 2008 10:04 AM
redflaredb1690
May 12, 2006 01:56 AM
civicmatt
Jun 22, 2003 07:27 PM
H23vtecEG
Apr 4, 2003 08:12 AM
