throttle sticking shut!
Like the title says. It's always sticks a little, which is annoying, but recently it's been sticking soo hard that it won't open when I step on the gas pedal (I bent the pedal to the floor ) I had to open it with a screwdriver. Tried cleaning out the throttle body w/spray stuff, lubed up all external parts, cable moves fine. What could this be?? Anyone else had this sort of problem.....
Re: throttle sticking shut! (miahmouse)
Adjust your throttle stop screw on the throttle body to hold the throttle open just slightly. Don't go nuts with this adjustment or you will have serious idle problems.
mine was sticky..i took off the air intake arm and had a friend hold open the butterfly while i scrubbed w/ a toothbrush and carb cleaner. it worked.
LOLO93PRELUDE
07-07-2008 07:52 AM
Mr. JDM-GSR
08-29-2005 11:33 AM
