quick LS/VTEC question
Old Oct 7, 2002 | 11:43 AM
b18b98's Avatar
Default quick LS/VTEC question
Once the head is slapped on with all ports plugged and tapped with oil line installed to the LS block, can you just run a 98 type R ecu instead of having your stock LS ecu with a vtec controller?
Old Oct 7, 2002 | 12:19 PM
Charlie Moua's Avatar
Default Re: quick LS/VTEC question (b18b98)
haha not that simple and easy bro.
Old Oct 7, 2002 | 01:27 PM
lazy bum shaughn's Avatar
Try to get your hands on a chipped P28.
Old Oct 7, 2002 | 01:32 PM
vtec69's Avatar
def go with the chipped p28
alot easier then using the itr
Old Oct 7, 2002 | 08:31 PM
infamousALLMTR's Avatar
Default Re: quick LS/VTEC question (vtec69)
not if he has to get a obd2-obd1 coversion...
Old Oct 7, 2002 | 08:34 PM
BoOsTeD_eK's Avatar
If you have a 96-98 vehicle then you can use the ITR with no problems...just run the knock, vtec, and vtec pressure to the corresponding pins on the ecu. PLUG AND PLAY sort of.
Old Oct 8, 2002 | 06:12 AM
b18b98's Avatar
Default Re: quick LS/VTEC question (BoOsTeD_eK)
thanks.
Old Oct 8, 2002 | 07:48 AM
X2BOARD's Avatar
That depends... what head did you use ? GSR or B16 ? (or ITR...) The ITR ecu, if you are already OBD2, will have the best fuel maps for a B16/ITR head/mani combo. If you have a GSR head, the GSR ecu would be better for fueling.
bboysake
Jul 10, 2006 09:44 AM
HondaTeg95
Sep 28, 2005 07:42 PM
my_slow_civic
Mar 14, 2004 05:28 AM
B18C-RnVA
Dec 22, 2002 01:47 PM
awskalis04
Aug 5, 2002 04:51 PM
