H22 Civics, what clutch master cylinder did you use?? civic or prelude?
I'm asking because I'm still using the civic one (i think) and my car will not let go of the damn gear at high rpms (past 6800). Would this be because the civic clutch master cylinder rod is shorter than a prelude? Anyone else have this problem? I don't get any grinds whatsover, but I have to bang the gears because it feels like my tranny doesn't want to let go of them. Help a brotha out, thanks
Re: H22 Civics, what clutch master cylinder did you use?? civic or prelude? (H22AMedina)
come on, i know someone here is willing to lend a helping hand
Your clutch may need to be bled. Or try changing your tranny fluid. I don't think the clutch cylinder has anything to do with it.
If the adjustment & new fluid doesn't work I'd be blaming the clutch disk, perhaps it's not disengaging.
[Modified by wheemer, 2:21 PM 10/7/2002]
Re: H22 Civics, what clutch master cylinder did you use?? civic or prelude? (wheemer)
I've bled it before with no difference. The reason I say the clutch master cylinder may be wrong is because the rod that the clutch pushes in a prelude may be longer than the civic one
BTW.....I used the stock Prelude one (97+) and its doing good.........Gave a modded S2000 hell with 2 other people in my car
Mark
[Modified by SlvrEj6Dx, 1:18 AM 10/8/2002]
Re: H22 Civics, what clutch master cylinder did you use?? civic or prelude? (SlvrEj6Dx)
i think ur talking about the slave cylinder not the master cylinder..the slave is the one on the front of tranny...i used the stock lude one with my stock civic clutch line screwed into it..worls great..no probs..
Re: H22 Civics, what clutch master cylinder did you use?? civic or prelude? (jDmDxTuRd)
I think I am currently leaking fluid from the hardline into the housing on the tranny. Does anyone know what size the fittings are by chance. I might just upgrage it to a stainless steel line just to get it out of the way..
Re: H22 Civics, what clutch master cylinder did you use?? civic or prelude? (Jason kiDD)
whatever it's called, I'm talking about the one attached to the clutch pedal. When I said I 've bled it before, I meant the clutch (the bled bolt attached to the tranny). Some other people say it may be my shifter cables binding, but why would happen to me and not other people?
Okay the only reason why you might have problems shifting is because you might have a leak in your line somewhere. I would check the fluid levels and see if it goes down at all. If not then bleed the clutch from the screw located on the slave cylinder in the front...
Make sure you have enough tranny fluid as well.
I used the prelude slave cylinder without any problems, just had to shave off a little of the bleeder screw to clear the slim fan properly..
Okay, i just bought new Prelude clutch master and slave cylinders on ebay for my H22 EG. They will both bolt up fine, correct? Or did I make a boo boo?
Sorry to bump this 4 year old thread, but it's better than creating a new one right?
i have a question. doing a f20b swap into ek, similar to h22. would a 2000 accord shifter box work/fit? thank you.
MasterLink4253
06-09-2014 07:22 AM
Lei Siew Long
10-22-2002 10:43 AM
