S1 tranny...
Re: S1 tranny... (1fastEK)
it never came with stock LSD. And i dont think it was an option either. So if it does have one it is probley aftermarket. You can tell buy if you pull you axels out of the tranny and look trough the hole. If you can see straight threw then you have LSD. if there is a bar there then you have no LSD. Also. sometime, sometimes it may be stamped on the tranny, by the egine code
