new swap jumps at idle
when i started my 96 jdm b18c it only idles but it jumps it will not idle at one speed it constintly jumps and when ever i give it gas it just bogs out,......what can it be, when i hooked up the engine hoist the tip on the fuel pressure regulator got bent but i bent it back could that be it??? it seems like its not getting enough fuel or maybe its the spark, but has anyone else had this problem with a new hybrid, particulary with a jdm hybrid i need to know i cant wait to drive it
Re: new swap jumps at idle (ekhatchhybrid)
i also forgot to add that i have a skunk 2 intake manifold and am not sure if i have everything connected correctly does anyone know a link to installing a skunk two intake manifold on a b18c so i can see if i did it correctly
Re: new swap jumps at idle (97hb)
were are they located?? could that be casueing it to bog out?? and i dont have any check engine lights
i know i dont have the pcv valve hooked up correnct becasue i had to get 2 type r pcv hoses and do not know were to connect them
[Modified by ekhatchhybrid, 5:03 AM 10/14/2002]
you might want to try switching your TPS and your MAP sensors. when i tried taking my car to the muff shop, i didn't make it half way down the block. the car would start perfectly but just wouldn't keep steady. i switched the MAP and TPS sensor plugs and it worked fine. HTH
Also, my car bogged out whenever i tried to give it gas, it would rev up and then shoot back down and wouldn't keep a steady rev in gear.
[Modified by p r ! m o, 9:56 PM 10/13/2002]
Re: new swap jumps at idle (p r ! m o)
My JDM 94 B18C did the same thing when we first started it up. It turns out that we needed to replace the spark plugs and coil. . .after that, the engine runs like a champ.
I had the same kind of "bog" feeling at first, and we thought it might be low on gas, so we filled her up, and that didn't fix the problem. . .that is when we started to try the minor things like plugs and coil.
johnjohn072002
06-07-2007 01:04 PM
