96 CX with JDM B16A.... Need Some Help
My friend just bought a JDM B16A for his 96 CX hatch. I've done three swaps and I know the wiring pretty well. I haven't swapped motors in an EK so there a few things that I'm unsure of. He has the tranny from a 00 Si, JDM B16A OBDI longblock but all the mounts are missing from both the motor and tranny. He's going to run a chipped P28 or P30 ECU (never got one yet) and an OBDI jumper harness.
My main concerns are the mounts. I know he needs a 99-00 Si rear engine bracket. I know that the driver's engine bracket need to be changed to the 99-00 Si bracket since the motor is from an EG. Will his stock rear engine mount bolt up to the 99-00 Si bracket? Will his stock driver's engine mount bolt to the 99-00 Si bracket? I think he needs to buy the 99-00 Si tranny front mount and upper bracket. If anyone has this setup let me know what he needs to use because I am going to install it next week.
Re: 96 CX with JDM B16A.... Need Some Help (VTECVillain)
this should be everything youll need for that swap
http://hybrid2.honda-perf.org/scottdr.html
go to the end of the page theres a list
good luck
[Modified by vtec69, 11:17 AM 10/10/2002]
good luck
Re: 96 CX with JDM B16A.... Need Some Help (vtec69)
Re: 96 CX with JDM B16A.... Need Some Help (Trey)
but i also remember one of the part numbers was wrong for one of the mounts..
i think the rear bracket...? at least compared to H-Aparts.com
Re: 96 CX with JDM B16A.... Need Some Help (VTECxSiR)
Its' a correct part number. The website is mess up, if you call them or the Honda parts counter, they'll quote you a price on that part number.
I used all those parts for my swap and had no problems.
Good luck!
Good luck!
ANGELIQUE
03-15-2005 12:25 PM
VTECVillain
10-08-2002 09:38 PM
