h22a-civic
I have a civic with a H22A, it’s a 94si 5g. I took the car after building, to the dyno and it pull 174hp to the wheels, and then I took it to the weight station and its heavy, 2590lb with me in it (190lb.)Does anybody now what the car should run at the track?
My car will be slower then a 5g with an ls/vtec right?
damn that SI is heavy...
there are so many factors....depending if the LS/Vtec is built right...driver...etc... can't really tell. however, your h22 should pull niiiiice.... tell us ur time when u run.
14.32 This is what you COULD run with perfect launch and shifting etc. Check the link if you like. I'd save it too because it is pretty useful.
http://www.rx7.org/Robinette/et.htm
Thats cool I was guessing 14.5 at about 95mph. The guys with b18 are about 75-85 pounds leatter, and with a good ls/vtec at about 184hp you get 13.9
I doubt the link is accurate...people with stock h22's in integra's that weigh 2700 - 2800lbs are hitting high 13's... I think with proper driving...u should run about 13.7 -13.8
jumpmann23
14
Mar 25, 2003 01:41 PM
