B18C1 in 88-91???
Re: B18C1 in 88-91??? (hybridRhatch)
couple different ways.
1 way: you are pretty much buying a complete B16A SiR I changeover minus the motor. PR3/PW0 ECU, cable tranny with matching axles, and shift linkage. you need the hasport mount kit and a drivers side mount from a 90-93 integra or 1st gen b16. Get a skunk2 intake mani or gut the 2nd butterflies. Run the PR3 and use 1st gen b16 injectors with the resistor pack (B18A injectors should work too). Would probably need a B18A exhaust manifold for the 2 O2 sensors as well.
2nd way: Cable tranny with matching axles, 90-93 integra or 1st gen B16 drivers side mount, linkage, P72 computer, stock GSR longblock, and flywheel/clutch/PP to match the tranny. I know that a 94+ GSR clutch will not work with a 1st gen b16 tranny. Also need Hasport mount kit. Use 94+ exhaust manifold, wire the 4 wire O2, and stock intake manifold. Wire the car for OBD I and use the P72 computer.
Good luck, option 2 is fun
