ecu question
I am in the process of doing a mini-me swap on a 93 Del Sol. I have the head on and everything is going good, but I ran into a few questions. First of all the d15b7 has an extra coolant outlet that went to its head that the d16z6 block and head don't. Do I just need to block it off or what? Second of all, I will be using a p61 ecu out of a 92 GSR. From what I understand, there is no need to move any pins, but to just add the yel/grn VTEC wire to A4 on the ecu, and to run the blue wire from the VTEC oil sensor to D6 on the ecu. Is this correct or am I mistaken? I have found many links on mini-me's, but they all seem to be concerning CRX's and 4th gen's. Thanks in advance.
gophat
Sep 11, 2006 07:29 PM
X2BOARD
Aug 15, 2002 04:35 PM
