SOHC vtec into 87 possible??
Re: SOHC vtec into 87 possible?? (JCracer723)
the D16Z6/D16Y8 engines are not bolt-in. better choices are: D16A1 (86/87 Integra), and brown-top JDM ZC. Both are 1.6L DOHC non-VTECs, and are bolt-in deals, but you have to use the trans., axles, linkage, ecu, wiring harness, hubs, knuckles, and rear bracket from the 1st gen 'teg (i might be forgetting something here). the brown-top makes more power, but obviously has to be imported, which usually means more $. Best bet is to do what i did and find a salvage yard 86/87 'teg 5 speed. they all have the same engine. only 113 hp, but mine will definitely sneak up on a 99 Si. HTH
Re: SOHC vtec into 87 possible?? (clemsonsi)
yes they are i look into other forum and i came out with this link
http://www.geocities.com/crx1stgen/1stGenHybrid.txt
hasport has a mount kit for you and it will allow the brute power from a bseries to bolt right in....
www.hasport.com
www.hasport.com
sushibug
01-19-2003 06:11 AM
