how to check engine codes
Old Oct 13, 2002 | 03:34 PM
kuelerz's Avatar
Default how to check engine codes
i need some help with this, i finished my swap of an obd I b18c into my 98 civic and i used a skunk2 conversion harness to put in from an obd II to a I and i need to know where and how you check it for codes. i want to clear up the engine light prob before i put the turbo on.
i am getting tired of looking at the drag 3 kit sit on my floor in my room.
Old Oct 13, 2002 | 04:36 PM
enhancedCL9's Avatar
Default Re: how to check engine codes (kuelerz)
check the ECU when car is running, then it should flash some codes. If that's what your asking?
Old Oct 13, 2002 | 04:50 PM
MPower332TI's Avatar
Default Re: how to check engine codes (SLOW CRX)
obd i ecus dont falsh codes threw a little window in the ecu like non obd cars do.(although i wish they did) u have a jumper wire above the ecu wiring..its a little green plug..stick a paper clip in the connecter and the light on the cluter should flash...good luck
Old Oct 14, 2002 | 09:20 AM
kuelerz's Avatar
Default Re: how to check engine codes (jDmDxTuRd)
so this will still work even if i used the conversion harness
Old Oct 14, 2002 | 01:16 PM
Carlito Brigante's Avatar
on the kick panel on the right hand side of your car which i am sure you already know is a green rubber boot. in it you should find a plug. take a pin put it in there go from one side to the other.
with the car off put the ignition to the on acc position. when you do this your srs light will flash.
long flashes are that number times 10. like 9 long flashes 90 or evap systems failure etc etc.
all the short flashes are that exact number
so like 1 long 2 short is 12.
if you have more than one code it will pause then throw some more codes.
any questions im me, i have a COMPLETE list of the obd1 ob2 codes for the ecu.
hope that helps.
Old Oct 14, 2002 | 01:17 PM
Default Re: how to check engine codes (fiaddictedsi)
ps skunk2 wiring harness just uses all the obd2 pinouts and minimizes them to the obd1. obd2 has more wires and sensors, some of them are eliminated and some of them are spliced into others so you can adapt the obd1 ecu and motor.
it will still throw codes.
go standalone!!
turboZChatch
Sep 30, 2004 01:30 PM
illestrolla247
Sep 8, 2004 10:39 AM
imlachg1
May 5, 2004 12:50 PM
gocivicgo
Aug 11, 2003 03:43 PM
Artful Dodger
12
May 21, 2003 09:09 AM
