Calling all +++JDM swap++++ gurus!!
I bought a SOHC JDM vtec d15b. How do I convert the JDM wire harness to plug up into my 92 cx? I heard I can use a 92-95 si/ex harness, but they're kind of expensive. Can I use my cx's d15b7 harness and add the vtec wire? If I can, does anybody have any diagrams or pics of any sort. All help is welcome.
thanx in advance.
[Modified by Touch, 4:51 PM 10/11/2002]
thanx in advance.
Re: Calling all +++JDM swap++++ gurus!! (Trey)
Seriously, why did you get a D15b? It has something like 92 hp doesn't it? I am just wondering if there is something about this engine that I am not aware of. Thanks.
Re: Calling all +++JDM swap++++ gurus!! (EF9_SiR)
JDM d15's are the motors the same motors in vti's, they push somethin like 127 ponies. The reason I got it instead of just holding out for my b18c1 is because my cx motor popped a piston ring and was burning oil and suffering from some serious back pressure.
As for turbo.... not quite yet. After I go dohc and build up the internals. I got the basic bolt ons from my former engine I just need the harness info.
Re: Calling all +++JDM swap++++ gurus!! (Touch)
If your looking to save a little cash, you can make the rhd harness work. It will reach.
Im using a jdm wiring harness w/ my b18c'r swap.
Re: Calling all +++JDM swap++++ gurus!! (slooowDX)
how do I do that? Where do I add the wire on the engine harness? If you have any diagrams that would help loads. thanks
when i did my swap i had to use my stock harness and cut all the plug ends form the Jdm harness and sotter them onto the stock one.
Re: Calling all +++JDM swap++++ gurus!! (kuelerz)
New User
Re: Calling all +++JDM swap++++ gurus!! (SuperCivic)
Wow a vtec e (economy) swap...why'd you do that again, (voice of buyers remorse). Sorry my 2cent comments arent helping.
[Modified by dothemath, 1:42 PM 10/16/2002]
Re: Calling all +++JDM swap++++ gurus!! (dothemath)
the 1.5 vtec vti engine and says VTEC on the valvecover (obd-1)
and just says HONDA on obd2 valvecover and it is 127hp
thats a 1.5 vtec-e engine, 92hp
Good luck
Good luck
Re: Calling all +++JDM swap++++ gurus!! (sirhatchback)
indeed a VTEC-E from a JDM Civic ETi (VX) rated at 94ps. not 130ps like a VTi d15b
giveaways:
valve cover VTEC-E = Economy (lean burn)
EGR = again to aid the environment
top mounted cat
super small intake/TB
tiny ports
3.25FDR tranny = economy (overall the car will be just as as fast as before (cx))
P07 ecu or P84 ETi ecu = 6500rpm rev limit with 90lb/ft of torque is simply crazy
now as far as the harness, which ecu if VTEC-E then you need to do much more wiring then you think. use your old one, add vtec wires, egr wiring, 5wire 02
giveaways:
top mounted cat
tiny ports
Re: Calling all +++JDM swap++++ gurus!! (eg6ajk)
Are you serious? That means I was duped. Dammit. HMO is responsible. I was told it was 127 horses. I'll be on the phone with them tommorrow.
thats what I was trying to say in my original post. Isnt it essentially, if not the exact, same engine from the 5g VX?
I spoke to dude this morning, he ensured me that it was definately 127hp because it was a jdm version. Still not sure about it, I've been looking for more info on the matter. anything you guys can find let me know., post the url or something.
BoostinEJ1
01-14-2007 11:49 AM
boostmywankle
10
05-22-2005 12:31 PM
Touch
02-11-2003 08:28 AM
