-> Need to know's when purchasing a used engine ....
Old Oct 7, 2002 | 06:59 PM
JDMEMM's Avatar
Default -> Need to know's when purchasing a used engine ....
What should I know/do before I go abouts purchasing an engine off of someone's car?
i've taken a test drive in it and the motor is strong and running fine.
1) will I just need to do a compression test, leak down test and vin backup check?
2) Also, are the VIN numbers on the car the same as the ones on the engine and tranny?
3) What exactly does 'papers' consist of?
since this is a private sale I need to know, thank you all for helping!
Old Oct 7, 2002 | 07:36 PM
RJonathan's Avatar
Default Re: -> Need to know's when purchasing a used engine .... (JDMEMM)
Oh yeah it would be better if you can watch the guy take the motor out. cause then you will know what your getting. and make sure he doesnt make mistake takening the motor out.. heheheheheheh
Old Oct 7, 2002 | 07:43 PM
JDMEMM's Avatar
Default Re: -> Need to know's when purchasing a used engine .... (RJonathan)
he's taking it out at a local shop.... can someone answer qestion #2 plz?
mynameizstitch
May 21, 2009 02:03 PM
HCJDM1
Jan 26, 2007 01:27 AM
vxnine
Oct 5, 2004 12:12 PM
stripes777
Mar 17, 2004 08:34 AM
JDMEMM
Oct 7, 2002 10:13 PM
