Auto to manual conversion parts list, please?
Hey everyone... I'm looking for a list of parts to do a auto to man. trans swap. on a 96 civic ex. I think I have everything but I want to make sure. thanks
if someone has a link to a thread with this info that would help also because i havent found one that is specific for my car
Re: Auto to manual conversion parts list, please? (seeNATgo)
the mount is the same just make sure u get a manuel bracket that bolts to the tranny from a civic and u will need pedals clutch master, lines, slave cylinder, and that will be it if you are getting an engine swap while you are at it, i just did mine but i am having troubles getting my b18c to idle right
Re: Auto to manual conversion parts list, please? (ekhatchhybrid)
this was needed for the accord swap
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 Prelude)
3. 5 speed shifter assembly w/ shifter cables (90-97 Accord 92-96 Prelude)
4. 5 speed drivers side axle (your year accord, but from 5-spd version)
5. 5 speed intermediate shaft (your year accord, but from 5-spd version)
6. 5 speed clutch pedal assembly (90-97 Accord 92-96 Prelude)
7. 5 speed brake pedal arm (90-97 Accord 92-96 Prelude)
8. Clutch master cylinder w/ reservoir (90-97 Accord 92-96 Prelude)
9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude)
10. Clutch dampener assembly (90-97 Accord 92-96 Prelude)
11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude)
12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude)
13. Slave cylinder (90-97 Accord 92-96 Prelude)
14. Clutch (90-02 Accord 92-01 Prelude)
15. Flywheel (90-02 Accord 92-01 Prelude)
16. 5 speed mount (Your year, 5-spd version)
17. 5 speed mount bracket (go to honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes)
18. MIG WELDER (see notes)
19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt
Re: Auto to manual conversion parts list, please? (KTeller8)
Your also going to need a 5-speed intake manifold & throttle body if you want to use a 5-spd ecu. You need the manifold because the idle air control valve mounts to it unlike automatics which mount directly under the throttle body.
Re: Auto to manual conversion parts list, please? (civiconboost)
so what it wont idle right if you dont move it, im sorry i dont understand why you have to change it if it does the same job and puts ou tthe same signal.. if you can give me more info
Re: Auto to manual conversion parts list, please? (ViZ)
I was able to use my auto ecu when I did the auto to manual swap in my '96 civic but had an annoying cel saying someing was wrong with the auto tranny which of course wasn't there! So I picked up a manual ecu (same year) plugged it in and the car started idling funny. I tried adjusting the idle air control screw on top of the trottle body but that didn't help.
Long story short, turned out the auto and manual idle air control valves are different. I took it to a shop that changed the iac valve wires around at the ecu (not sure which pins they changed) and they sandwiched a paper gasket inside the auto iac valve so the car would idle right. They told me I would need a manual throttle body and iac valve. I didn't have to change my manifold because I have a jrsc and there kits are made for both auto and manual so the iac valve bolted right up.
The car ildes fine now without any cel's.
Here's a manual manifold/throttle body/IAC valve
http://www.hondaautomotiveparts.com/...E+BODY+%282%29
Here's an auto manifold/throttle body/IAC valve
http://www.hondaautomotiveparts.com/...E+BODY+%283%29
[Modified by civiconboost, 5:36 PM 10/16/2002]
do you know if the car runs in a safe mode with the auto ecu? like will vtec kick in still?
oh thanks for the info by the way, nat and i are about to do the swap and im trying to get as much info as possible
That is one of the reasons I switched the edu. Some people said it did and others said it didn't , I don't know for sure. I really didn't notice a differece between the two , then again I was already running my fuel settings way rich because of the jrsc maybe that's why I didn't notice.
Have you checked out the article on the hybrid site about switching from auto to manaul? It has some good info about wiring up the backup lights and what to do with the gear selector switch.
Let me know if you have anymore questions
THEROPE
03-03-2014 05:36 AM
skingfreak
05-04-2007 08:34 PM
