MAP Question for B16a
Old Oct 9, 2002 | 05:34 AM
mraudio13's Avatar
Default MAP Question for B16a
I have an 88 civic STD that does not have a Pressure Regulator Cut Off solenoid valve. I have put a B16a (90 JDM) in it and was wondering if i need this Valve?
[img]C:\My Documents\My Pictures\vacuum.jpg[/img]
[img]C:\My Documents\My Pictures\vacuumd16.jpg[/img]
Old Oct 9, 2002 | 06:10 AM
SuperCivic's Avatar
Default Re: MAP Question for B16a (mraudio13)
[img]C:\My[/img]
[img]C:\My[/img]
ok, first of all you need to upload your pics to imagestation or photoisland to post them, you can't just link them to your hard drive.
second, you can set up your b16 to run w/out that extra solenoid.
Old Oct 9, 2002 | 10:43 AM
mraudio13's Avatar
Default Re: MAP Question for B16a (SuperCivic)
How do i Run the Map lines then. Right now my FPR line is teed into the back of my intake manifold then into my purge cut off valve. Is thisa the right way to do this??
matt
Old Oct 9, 2002 | 11:23 AM
SuperCivic's Avatar
it's been awhile since i did my b16 vac lines, but if i remember right i t-ed the two lines running along the back of the manifold together.
Murk 'EM
Jul 21, 2009 08:23 PM
Turbo88hatch
Jan 24, 2003 10:37 AM
racerxadam
10
Jan 20, 2002 04:37 PM
GeeSeeR
Jul 30, 2001 11:38 AM
