ls swap questions..
ls swap questions..
im planning to swap out a 1st gen b16 for a ls motor(car is 90 teg) and i have 3 main questions....
1) will i be able to use the same wiring harness?
2) must the tranny be cable clutch? ( keep in mind 90 teg....its a cable setup right now)
3) will i be able to use the same axles(im guessin yes but im not too sure)
Thanks for your help yall....
peace
peace
Re: ls swap questions.. (g5raprentice)
b18a or b18b, year?
1. What kind of harness are u using b4 w/ b16? if it's 90 LS harness that u can use.
2. Use the the one from the b16.
3. The axles that you have will do.
