JDM d15b
Old Nov 3, 2003 | 04:07 AM
importstyle's Avatar
Default JDM d15b
i am looking to go to a d15b... and i have a stock dx motor with everything in my civic.... i just need to know what i would need for the swap......
Old Nov 3, 2003 | 04:23 AM
eg6ajk's Avatar
Default Re: JDM d15b (importstyle)
just make sure you get the right d15b as there are two kinds. One is a Vtec-E as in d15z1 up here but still labeled d15b in JDM land. Other is equivalent of the d16z6 in many respects.
Old Nov 3, 2003 | 04:50 AM
Default Re: JDM d15b (eg6ajk)
i want the kind that is the equivalent to the sohc vtec..... what do i need for the swap anything?
Old Nov 3, 2003 | 09:11 AM
cccya's Avatar
if you get the "right" one no you don't need anything for the swap.
As far as i know.......
Old Nov 4, 2003 | 08:51 PM
egcivic's Avatar
Default Re: JDM d15b (cccya)
hmmmm.... i have a 92 dx too
and i want to do this same swap
form what i hear you need a vtec ecu (p28 i think will work)
u prob need to wire a little for the vtec
and you need a vtec controller
a clutch prob a good idea also....
but everything should pop right in
yea but talk to eg6turbo or usdm 4g vtec
they have done this swap and can help you out
yea check hmotorsonline.com they have the engine
tell me if u find one cheaper
thanx
Old Nov 7, 2003 | 03:26 PM
iwhichisme's Avatar
just 2 extra wires for vtec, prefferably and ex tranny, and either a p28 or p08 ecu. Everything else is plug and play.
Old Nov 7, 2003 | 07:28 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you get the right d15b as there are two kinds. One is a Vtec-E as in d15z1 up here but still labeled d15b in JDM land. Other is equivalent of the d16z6 in many respects.</TD></TR></TABLE>
actually there are three versions, the two you mentioned and one with 3-stage VTEC, 128hp - has 2 VTEC solenoids
krisfnbs
Honda Civic (2001 - 2005)
31
Jul 28, 2022 04:17 PM
travishoward
13
Jul 29, 2010 02:43 AM
4DRmafia
Mar 21, 2006 09:24 PM
94civicspeed
Dec 30, 2004 03:38 PM
Simon Tibbett
24
Dec 7, 2004 03:31 AM
