I need HELP!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 27, 2003 | 10:33 AM
JOJO0420's Avatar
Default I need HELP!!!!!!!!!!!!!!!!!!!!!!!!!
I have a 99 Civic EX with a d16y8. Lat year I spun a lower rod bearing. I took the engine out rebuilt it with .040 bore and now it is acting up agian. It is sputering and sometimes backfireering. I hooked up a snap on scan tool to it and it is throwing a code for the vtech and for a knock sensor. but I was told that there is not a knock sensor in the d series engine????
I am thinking about getting a b16a engine and swaping it out but I am not able to find a usdm. All that I can find is jdm and I was told that the reason for there being so many jdm's is that they have emission problem that is why you see them with 30,000 miles on them the are always taken out over in Japan! WHERE CAN I FIND AN ENGINE THAT WILL PLUG AND PLAY?
Old Oct 27, 2003 | 10:56 AM
hondaZvic's Avatar
Default Re: I need HELP!!!!!!!!!!!!!!!!!!!!!!!!! (JOJO0420)
first.. its vtec. not vtech...
2nd.. on the d16y8, i wouldnt know, cuz i just took mine out, and put in the H
3rd.. grab a jdm if u can, its better that way. dont worry bout that smog/30kmile ****...we're in the US. its all good.
Old Oct 27, 2003 | 11:47 AM
slixxracing's Avatar
the only reason JDM motors are always listed at 30k-40k miles is cause of the smog purposes over there. In the US we need to smog our cars, in Japan they dont need to. Im assumming they replace their engine's every 30k-40k miles. Thats why we have so many quantities of JDM motor here in the US.
You are also right about the civic motors. They do not come with knock sensors, not that I know of about the d16y8. But I know that the d16z's doesnt come with knock sensors. Maybe it's because of installation on the rob bearings and so forth. Check your rods also to see if they are slighty bent.
Old Oct 27, 2003 | 03:06 PM
poison's Avatar
Go to Hmotorsonline.com and talk to Steve.
D16Y8 (which you have), B16A2, JDM OBD2 B16, B16B, and B18C5 will be plug and play.
Old Oct 28, 2003 | 04:47 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOJO0420 &raquo;</TD></TR><TR><TD CLASS="quote">I hooked up a snap on scan tool to it and it is throwing a code for the vtech and for a knock sensor. but I was told that there is not a knock sensor in the d series engine????</TD></TR></TABLE>
The 96-00 D16Y8 SOHC VTEC motors have a knock sensor.
Old Oct 28, 2003 | 04:53 AM
hondaZvic's Avatar
Default Re: I need HELP!!!!!!!!!!!!!!!!!!!!!!!!! (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
The 96-00 D16Y8 SOHC VTEC motors have a knock sensor.</TD></TR></TABLE>
ur right, i shoulda known that, i didnt remember having to run an extra wire for knock. it was already there. hehehe
TekSI
14
Feb 21, 2011 08:45 PM
redlines4us
Jun 29, 2009 04:26 AM
DOHC Kid
May 18, 2008 12:00 PM
rickgiblin
Jul 22, 2006 02:30 AM
brcivic411
Oct 23, 2003 11:55 AM
