Help on 6th Gen Accord H22 Swap
I got the car with the motor and manual tranny in, yes, auto to manual. It is a 1999 Accord LX with an OBD1 H22 swap, manual tranny conversion, OBD1 P13 ECU and OBD2-OBD1 conversion harness. Got it running and what not, but has no speedometer and throws a code 41 (primary 02 sensor heater). Any pointers?
Jason
Jason
Re: Help on 6th Gen Accord H22 Swap (FSTASNTZ)
well.. that should be easy, recheck ur wiring and make sure the o2 sensor wires are not crossed or anything.. that should be just plug and play, then if anything.. replace the o2 sensor.
Re: Help on 6th Gen Accord H22 Swap (hondaeg5)
All I know is that it is OBD2 version 2 to OBD1. Not sure who made it.
All the wires are in the original location, I did not repin any of the harness. What is am hearing is that I need to repin for the 02 and Speedo. Just not sure to where or even if that is the problem.
Jason
Jason
i have heard that you do have to repin that just look at a honda etm for your car and then for the car w/ the ecu u are runnin and make the relocation if you cant get yo hands on a honda etm book just let me know for what cars and ill look it up monday when i go to work good luck
Re: Help on 6th Gen Accord H22 Swap (KUSTOMKONCEPT)
If your speedometer doesn't work...is your VSS hooked up? (Vehicle Speed Sensor) it's in the top of the tranny at the back.
Re: Help on 6th Gen Accord H22 Swap (satan_srv)
It is hooked up. I have checked and rechecked it to see that everything was in the correct pin at the VSS.
Jason
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 »</TD></TR><TR><TD CLASS="quote">which conversion harness you got? im having a problem with a skunk2 jumper as we speak. p.o.s </TD></TR></TABLE>
no ****!!!
mine isnt even worth the dirt i walk on... when i got it.. there were already wires loose when i opened the box.. i was like Fck it... i just resoldered them myself. oh and then my conv. harness doesnt even have wires ran for my egr. i gotta run those myself... fckN crap man....
ps
mine is skunk 2 also
no ****!!!
ps
Re: Help on 6th Gen Accord H22 Swap (hondaZvic)
Got the 02 sensor problem fixed. Turns out on the OBD1 P13, the heater circuit gets its power from the coolant sensor circuit. So, I just tapped into it, and bingo, no more code...
Now for the VSS.
Jason
Now for the VSS.
Jason
Former Sponsor
Hey Jason (FSTASNTZ) What engine mount did you use for the driver side? Did you use the bracket from a prelude?
Thanks.
Thanks.
Re: (klutch44)
I have a 2001 h22 turbo accord. for the driver mount i used part prelude and some steel to extend it. but there is another way,i heard the euro r will work.im researching it now ,and it looks promissing!as for the speedomiter it could be a few things,first does work at all ?if not, you have a bad connection from the vss. This can happen if you if you pull the plug to hard,it pulls the pins slightly out of wack.also you can tone with a multi meter to the ecu.make sure the pins are correct.im me if you need more help.good luck
