h22 wiring question
Old Nov 7, 2003 | 02:16 PM
b16hybridsol's Avatar
Default h22 wiring question
what do i wire the yellow plug on the thermostat housing to, i searched already and couldn't find, set up is 94 teg ls obd1 jdm h22 and a 96 gsr wiring harness, also i've converted the distributor wires, injector plugs, added resistor box extended various wires, i've got an extra plug on my passenger shock tower, 3 wires blk/purp that turns into blu/red, red/yel and wht/red. what do i do with this plug? i've searched but haven't found any one with this setup and problem, thanks
Old Nov 7, 2003 | 04:43 PM
poison's Avatar
Default Re: h22 wiring question (b16hybridsol)
The yellow plug goes to the fan switch on the thermostat housing.
If you have the three major plugs plugged into the shock tower harness, then that 4th plug is not needed.
Old Nov 8, 2003 | 01:55 PM
what wires are the fan switch, isn't that the temp sensor to control the fan on the head under the distributor? thanks
Old Nov 10, 2003 | 11:28 AM
? bump
Old Nov 10, 2003 | 04:16 PM
hondaZvic's Avatar
fan switch wires? wires that plug into the fan? that should be on the harness in ur car already, u should just stick the fan in and there should be a plug rite there.
Old Nov 10, 2003 | 04:21 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">what do i wire the yellow plug on the thermostat housing to, i searched already and couldn't find, set up is 94 teg ls obd1 jdm h22 and a 96 gsr wiring harness</TD></TR></TABLE>
That would be the thermo switch on the thermostat. The OBD1 and OBD2 motors have the thermo switch there, so if you are using a 96 GSR harness then the plug should be in the general area, just plug it in.
Old Nov 10, 2003 | 05:39 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">what wires are the fan switch, isn't that the temp sensor to control the fan on the head under the distributor? thanks</TD></TR></TABLE>
The temp sensor on the head for the ECU (if I remember correctly). The ECT on the thermostat housing for the cooling fan. The Sensor (at a certain degree (196)) it gives the cooling fan ground. VTECVillain is right. OBD0 ECT is on the block. plug that bad boy in.
Old Nov 11, 2003 | 04:59 PM
i had it pluged into the head but i wasn't sure if it was supposed to plug there or to the yellow pluf on the thermostat housing, thanks guys
rustanghunter
Jun 14, 2010 06:58 AM
slvrlude
Sep 3, 2008 09:38 AM
Skeletor
Mar 13, 2008 12:23 PM
blinger
Apr 25, 2007 02:00 PM
neonphire8604
Aug 8, 2006 08:00 PM
