which headstuds are used for LS/VTEC
Old Nov 3, 2003 | 01:17 PM
turbo*s2k's Avatar
Default which headstuds are used for LS/VTEC
Just like the topic reads. Does it matter which cylinder head your using? (b18c or b16). Would the block make a difference in which ones you use as well. (LS or B20)
Thanks for the help.
I did a search but I didn't find anything specifically...
Old Nov 3, 2003 | 04:14 PM
turbo*s2k's Avatar
Default Re: which headstuds are used for LS/VTEC (TurboChrgd_Civic)
no one knows?
Old Nov 3, 2003 | 04:42 PM
crazydude75927's Avatar
arp has an ls -vtec head stud kit
Old Nov 3, 2003 | 06:39 PM
mr. wu's Avatar
Default Re: which headstuds are used for LS/VTEC (crazydude75927)
you can use gsr head studs.
VtecDA9's Avatar
GSR/ITR are longer than LS and B16... Those are recommended stock replacements.
Old Nov 3, 2003 | 07:06 PM
Newman's Avatar
New User
Default Re: which headstuds are used for LS/VTEC (mr. wu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. wu &raquo;</TD></TR><TR><TD CLASS="quote">you can use gsr head studs. </TD></TR></TABLE>
Correctamundo .
If you get ARP head studs, get the ones for the GSR, but still bolt them down to spec.
Old Nov 3, 2003 | 09:54 PM
turbo*s2k's Avatar
Default Re: which headstuds are used for LS/VTEC (Newman)
Can you use B16 head studs on an LS/VTEC. The reason I ask is because my friend did an LS/VTEC for some guy, and the guy claims that the car started smoking so he took it to a shop where they pulled the head off, and 3 of the headstuds were stripped, and some even broke in the block. Is this possible from just normal driving? Sounds to me like the guy was over reving or something... I know he was running a Skunk2 chipped ecu with a 9000 redline.
Old Nov 4, 2003 | 07:32 PM
Cractos's Avatar
Default Re: which headstuds are used for LS/VTEC (cbpro)
hey i was just wondering if i could use ARP b18a bolts and studs for my ls/vtec...I have a b18a bottom and b16a1 head.. They are 11mm on the ARP website....Will these work..
Old Nov 5, 2003 | 03:23 PM
turbo*s2k's Avatar
Default Re: which headstuds are used for LS/VTEC (Cractos)
ARP sells B20/VTEC bolts, but I think there also used for LS/VTEC. The LS, and B18C bolts I believe are the same lenght...
Old Nov 5, 2003 | 10:29 PM
Cractos's Avatar
so can i use the b18a ARP bolts with my ls/vtec
Old Nov 14, 2003 | 01:49 PM
Cractos's Avatar
so can I use them
gs-r94coupe
Jan 1, 2011 07:55 PM
almostjdmeg
Jan 3, 2009 07:41 AM
aemintgsr
Apr 7, 2007 11:52 AM
See Are X
Oct 10, 2005 07:13 AM
SoloSol
Jan 9, 2002 04:38 PM
