Direct Swap? SIR1 B16 into 94 Civic?
Re: Direct Swap? SIR1 B16 into 94 Civic? (Motor-Tek)
taken from hasport
"A combination of stock Civic and Integra mounts can be used if a hydraulic B-series tranny is used. You will need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year."
so no.
so no.
Re: Direct Swap? SIR1 B16 into 94 Civic? (importimage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage »</TD></TR><TR><TD CLASS="quote">What would be needed for a JDM B16 swap into the 94 civic?</TD></TR></TABLE>
Read what Kamin said....
Re: Direct Swap? SIR1 B16 into 94 Civic? (VTECVillain)
i did a sirII swap into a 93 civic, it was probably this easiest swap. only thing different was knock sensor, axles, and ecu
Re: Direct Swap? SIR1 B16 into 94 Civic? (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz »</TD></TR><TR><TD CLASS="quote">i did a sirII swap into a 93 civic, it was probably this easiest swap. only thing different was knock sensor, axles, and ecu</TD></TR></TABLE>
no offense but a second gen swap has nothing to do with a first gen. totally diffrent platforms.
Re: Direct Swap? SIR1 B16 into 94 Civic? (Homey Da Clown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Homey Da Clown »</TD></TR><TR><TD CLASS="quote">Find a second gen cable one if money is an issue. Second gen cable b16A run for 1400 bucks. PM me for more details. </TD></TR></TABLE>
WHY?!
you need still eithre a hydro tranny or a cable to hydro conversion.
and please dont sell your **** in this forum. you want to sell pay for an advertisment like everyone else or take it to classifides if you arent a business.
WHY?!
so a 2nd gen it's all direct. A lot easier than changing from cable to hydraulic.... ****.
need2swapcivic
03-06-2006 09:18 AM
importimage
11-08-2003 04:07 AM
hj
09-26-2003 08:30 AM
