h22 tranny question
Re: h22 tranny question (Y49CRXSIZC)
It is a JDM trans and the lines are coming from and going into the Vehicle speed sensor, right? they are for the power steering in Japan. just loop them.
Re: h22 tranny question (ek2121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek2121 »</TD></TR><TR><TD CLASS="quote">It is a JDM trans and the lines are coming from and going into the Vehicle speed sensor, right? they are for the power steering in Japan. just loop them.</TD></TR></TABLE>
they are actually for the VSS (variable speed sensor) which is found on both USDM and JDM transmissions for the H22, H23. But since your car doesn't use that you can just loop them
Re: h22 tranny question (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX »</TD></TR><TR><TD CLASS="quote">
they are actually for the VSS (variable speed sensor) which is found on both USDM and JDM transmissions for the H22, H23. But since your car doesn't use that you can just loop them</TD></TR></TABLE>
uh i think you mean Vehicle Speed Sensor. they are not for that, they are for power steering. just loop em or plug em.
