Shift linkage
Old Oct 27, 2003 | 11:24 AM
CunninLynguist's Avatar
Default Shift linkage
Are all b-series shift linkage the same?
The shift linkage that came with my swap does not want to match up.
Its a jspec b18c and the shift linkage says ek on it.
Old Oct 27, 2003 | 12:27 PM
poison's Avatar
Default Re: Shift linkage (Scot project)
Depends on the car. if you are swapping a B series into an EG/EK, then yes B series shift linkage will work.
If it's an EF then you need to have it trimmed and re-welded to fit.
Old Oct 27, 2003 | 06:08 PM
MADEinJAPAN's Avatar
Default Re: Shift linkage (poison)
Still no luck man. So its too short...is that what you were saying in the other post?
Old Oct 28, 2003 | 04:38 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot project &raquo;</TD></TR><TR><TD CLASS="quote">Are all b-series shift linkage the same?</TD></TR></TABLE>
No all B Series linkages are not the same. The Del Sol VTEC has it's own linkage and the 90-93 Integra will only fit those years (or can be modded for EF B series swaps). Then you have the 94-01 Integra and 99-00 Civic Si which are interchangeable and will fit all 92-95 EG Civic's and 96-00 EK Civic's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The shift linkage that came with my swap does not want to match up.
Its a jspec b18c and the shift linkage says ek on it.</TD></TR></TABLE>
When you say it doesn't match up, is it too short? too long? or will it not even mount up properly? What car is this B18C swap going into?
Old Oct 28, 2003 | 02:28 PM
Default Re: Shift linkage (VTECVillain)
eh2 - Well it seems its alittle too short.
Old Oct 28, 2003 | 04:17 PM
Lookie here:
After messing with it for a long while i took it apart to see if it would be easier. I still didnt have any luck. But i snapd a pic of one part.
Does this look more bent then it should be?
Old Oct 28, 2003 | 04:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scot project &raquo;</TD></TR><TR><TD CLASS="quote">Does this look more bent then it should be? </TD></TR></TABLE>
A little bent??? Uhhhh that might be the reason it doesn't fit... If the linkage was meant to be connected to the steering rack it would probably fit fine
Old Oct 28, 2003 | 04:48 PM
Yea i thought so. damn it.
Well its now been some time since i bought the motor "complete change over" from this shop.
Do you think they should swap it out for a good one?
Old Oct 28, 2003 | 05:37 PM
Damn bro. That explains it.
Old Oct 28, 2003 | 05:51 PM
Default Re: Shift linkage (MADEinJAPAN)
Yep - I will find out what they say about it tomarrow.
Hopefully they will trade it out with a good one.
Its not like i fucked that up while driving.
Old Oct 28, 2003 | 05:59 PM
AL ASPIRATED's Avatar
wow, dat linkage doesnt look a little bent. it looks like someone used it as a weapon or sumtin. its not suppose to have dat curve
Old Oct 28, 2003 | 08:21 PM
Default Re: (JDMTyPeRHaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTyPeRHaTcH &raquo;</TD></TR><TR><TD CLASS="quote">wow, dat linkage doesnt look a little bent. it looks like someone used it as a weapon or sumtin. its not suppose to have dat curve</TD></TR></TABLE>
Well who ever got hit by this "weapon". I am sure they got messed up. Too bad i missed it.
- Do you think trying to bend in into the right shape would work?
yek99
Oct 6, 2012 03:42 PM
ramonjones16
Aug 13, 2009 10:44 PM
gsxrallday
Dec 22, 2007 02:55 PM
ITR EG
Aug 14, 2007 05:18 AM
SupraRXZ
Feb 9, 2006 04:35 PM
