h22 in eg problems... help on wiring!!
Old Oct 28, 2003 | 07:16 PM
electron-eg's Avatar
Default h22 in eg problems... help on wiring!!
my motor has been in for about a 3weeks now and i havent been able to get the car running, i got no spark from the coil to the pack. i checked all the wiring 1 by 1 and its all good. i replaced the distributor cap/rotor and still nothing. anybody help me out on some step by step troubleshooting? oh yeah, i got a 92 si hb with the complete changeover h22a kit from hmotorsonline. anybody recommend anyone down here in texas to check out the wiring? im pretty much **** out of luck and time. my daily driver just turned to a project car and i have nothing lese to get around in.
anybody's help will be greatly appreciated!!!
thanks in advance...
electron-eg
Old Oct 28, 2003 | 08:15 PM
Mark 2121's Avatar
Default Re: h22 in eg problems... help on wiring!! (electron-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron-eg &raquo;</TD></TR><TR><TD CLASS="quote"> i got no spark from the coil to the pack.</TD></TR></TABLE>
Sorry, I do not understand what 'pack' you are talking about. Are you getting power to the coil? Have you check the ignitor? You said that you got it from HMO, is it a JDM motor? Do you have the timing set, compression, and fuel?
Old Oct 29, 2003 | 05:48 AM
hondaZvic's Avatar
i see ur in laredo? where is that? im in lubbock.
Old Oct 29, 2003 | 08:04 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
Seems like the Ignitor may be bad...give that a check, i think the accord ignitor may be the same...try that first.
Old Oct 29, 2003 | 05:06 PM
H22aInside's Avatar
ignition fuse, ignitor, ground by thermostat
Old Oct 29, 2003 | 06:37 PM
fmfkid250's Avatar
i did an h22 into a 94 teg and no spark so i used an accord coil. because it is internal unlike the american ones
Old Oct 30, 2003 | 07:48 PM
sorry i didnt mean from the coil to the pack, i meant from the coil to the wires/plugs. when i touch the spring in the distributor it shocks the **** out of me so i know i got spark their. it is a jdm h22a motor from hmotorsonline. as for the timing set, compression and fuel, im not sure. i think the timing might have got retarted when it turned on for a sec. the first time. ever sense it hasnt started. they told me to check the crank sensor too. ill probably check the timing next. i work at the honda dealership down here in laredo,tx so i have the honda tech doing the swap but they never done a hybrid swap especially with a jdm motor. so im not even sure the wiring is correct. we used the h22 bible for the wiring. laredo is located 2 hours from san antonio. (bordertown).
Old Nov 5, 2003 | 10:20 PM
well it turns out the coil wa sbad, i switched it and it turned on the first try. so much for the 100%start up warranty from hmo.
Old Nov 6, 2003 | 04:39 AM
junglerunna's Avatar
Default Re: (electron-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron-eg &raquo;</TD></TR><TR><TD CLASS="quote">well it turns out the coil wa sbad, i switched it and it turned on the first try. so much for the 100%start up warranty from hmo.</TD></TR></TABLE>
Geez. You should consider yourself lucky that a part you can use from your stock motor was what you needed to get your motor running.
Old Nov 6, 2003 | 05:06 AM
hondaZvic's Avatar
Default Re: (junglerunna02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">
Geez. You should consider yourself lucky that a part you can use from your stock motor was what you needed to get your motor running.</TD></TR></TABLE>
yeah
laredo is far from me.
Old Nov 7, 2003 | 04:44 PM
h22civic95's Avatar
i need to know if i can use the stock harness out of my 95 ex up to and h22
Old Nov 7, 2003 | 06:07 PM
hondaZvic's Avatar
Default Re: (h22civic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic95 &raquo;</TD></TR><TR><TD CLASS="quote">i need to know if i can use the stock harness out of my 95 ex up to and h22</TD></TR></TABLE>
if you would search juuuuuuuuust a little bit, u might stumble upon this:
https://honda-tech.com/zerothread?id=650329
96ludedude
Apr 18, 2010 05:43 PM
laberone
Sep 18, 2006 06:42 PM
4drsedaneg
May 22, 2006 07:42 PM
JDMboostedB16
Sep 13, 2004 07:58 AM
