EK B20/LS swappers, why is my car is still leaking coolant?
ok, very simple to fix. But i'm still leaking coolant from my upper radiator hose at the radiator-connecting end. I got a B20 swap in my 98 civic. I was told to use a 94+ LS upper hose. I also bought the LS oem clamps for it. Hook it on to the block and stock civic radiator, but it's still not a very tight fit. Leaking in drops I tell ya.....does everybody fix this by using those adjustable clamps to tighten it up?
Re: EK B20/LS swappers, why is my car is still leaking coolant? (kinvid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinvid »</TD></TR><TR><TD CLASS="quote">I was told to use a 94+ LS upper hose. I also bought the LS oem clamps for it. Hook it on to the block and stock civic radiator, but it's still not a very tight fit. Leaking in drops I tell ya.....does everybody fix this by using those adjustable clamps to tighten it up?</TD></TR></TABLE>
The Integra hose clamps were made for the Integra radiator which has a bigger outlet than the Civic. You need to get a C-Clamp and tighten it down, sometimes even 2. You need to do this for both the upper and lower hoses.
Re: EK B20/LS swappers, why is my car is still leaking coolant? (VTECVillain)
But it looks so much cleaner with the oem clamps. Can i get a civic clamp to tighten it down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinvid »</TD></TR><TR><TD CLASS="quote">But it looks so much cleaner with the oem clamps. Can i get a civic clamp to tighten it down? </TD></TR></TABLE>
No, they are too small for the Integra hoses.
i had the same problem with mine. just a little bit of fluid would come out at a time but any fluid is enough to be concerned.
suck it up and get the adjustable clamps
93grayeg
01-31-2011 10:46 AM
bboy_mikey
09-17-2006 03:36 PM
ying_YANGtwin
02-01-2005 09:03 AM
