Code 15 ingnitor / coil
Old Nov 5, 2003 | 06:27 AM
st0nedstoopid's Avatar
Default Code 15 ingnitor / coil
All i did today was change the oil.. redo my switch to the fan and added a inline fues for the fan... and put a new rotor in .. and then my car wouldnt start.. then i threw code 15.. so i got a new coil set up and installed it.. and still wont start.. its late and i only let it crank about 3-4 times .. but i cleaned off all the connections, the very few that there where, checked my fueses and everythign is in the right place.. any help on this would be great.. iam running h22 ek wit p28
Old Nov 5, 2003 | 12:55 PM
jdm civic 2000's Avatar
Default Re: Code 15 ingnitor / coil (st0nedstoopid)
is this a stock coil or msd setup,possible a loose wire or bad coil
Old Nov 5, 2003 | 02:13 PM
Patch's Avatar
Default Re: Code 15 ingnitor / coil (jdm civic 2000)
I threw a code 15 a while back, it turned out to be my ignition switch. Make sure you have battery voltage at the + side of the ignition coil.
djnikko
Mar 1, 2004 09:12 AM
st0nedstoopid
Nov 5, 2003 07:22 AM
Patch
Jun 8, 2003 04:14 PM
