LS in to 00 Civic
Old Dec 8, 2003 | 12:50 PM
trbcivic's Avatar
Default LS in to 00 Civic
I just got an OBD1 LS motor and I am going to put it into my 00HB.
I am not sure which mounts to use?
How about the dizzy?
I did do an search but nothing really came up
TIA
Old Dec 8, 2003 | 01:04 PM
JDMBOLONI's Avatar
Default Re: LS in to 00 Civic (trbcivic)
u use everything from an 00 si (dohc vtec)
Old Dec 8, 2003 | 01:40 PM
trbcivic's Avatar
Default Re: LS in to 00 Civic (JDMBOLONI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMBOLONI &raquo;</TD></TR><TR><TD CLASS="quote">u use everything from an 00 si (dohc vtec)</TD></TR></TABLE>
ohic, some told me that I need to buy an mount kit, but I really do perfer the stovk honda mounts.
Thanks
Old Dec 8, 2003 | 04:50 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trbcivic &raquo;</TD></TR><TR><TD CLASS="quote">I just got an OBD1 LS motor and I am going to put it into my 00HB.
I am not sure which mounts to use?</TD></TR></TABLE>
No aftermarket mounts are necessary. You will need a 99-00 Si driver's side mount bracket and rear bracket. The upper tranny mount you can reuse the stock one. The front tranny mount bracket can be 99-00 Si or 94-01 Integra. Same applies to the A/C bracket unless you want to keep A/C. If so you will need a Del Sol VTEC bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">How about the dizzy?</TD></TR></TABLE>
You will need to get an LS/GS/RS or CRV nonVTEC distributor. OBD2 will be plug and play with your engine harness, you can also use an OBD1 Integra distributor but you will need to switch the plugs.
nihad
Apr 15, 2011 05:16 PM
htowncruiser
Mar 6, 2007 08:07 PM
Mr EJ1 203
Apr 8, 2006 10:25 AM
brasilstreet
Feb 28, 2004 07:48 AM
vspec12
Feb 5, 2002 02:55 PM
