Any one have an extra knock sensor connector plug?
i bought a motor with no engine harness, and now this is the only connector plug for th knock sensor. if it matters its obd1 motor and engine harness. any help would be appreciated. thank you
Re: Any one have an extra knock sensor connector plug? (DaStyle)
Any standard 2 prong plug from any OBD0, OBD1 or OBD2 engine harness will work. It's the same plug used for the IAT, VTEC pressure, most IACV's, etc. The knock sensor only has 1 lead going to it also, should be the top insert when plugged in but just match it to the sensor to be safe.
mtny
08-10-2008 09:07 PM
