which throttle cable to use on EG w/ B18B swap.... PLS HELP...
i just swapped a b18b in my 94 dx... i am rebuilding the B18C1 that i just took out of the car... im not really sure what kind of throttle cable was used for the B18C but it does not seem to work with the LS engine in there... any help would be appreciated... thanks
Re: which throttle cable to use on EG w/ B18B swap.... PLS HELP... (sirb18a)
since the configuration of the ls/b16/type-r manifolds are similar and your going to drop a b18 in your eg using the type-r throttle cable would be more ideal than a gsr.
j4s0n1337
12-29-2010 04:35 PM
