Will a GSR header fit a b16??
I need to know if a GSR header will fit on a b16a2? I think the top will but what about the rear flange? If not, is there a way to modify it to make it fit?
Re: Will a GSR header fit a b16?? (NEGATIVECAMBER)
The header will bolt to the motor perfectly. The GSR header b-pipe is about 4" shorter in length than a B16/ITR header. If the motor and exhaust are already installed in the car then there will be about a 4" section that will need filled between the GSR header flange to the cat or exhaust flange.
