h22 guys.
Old Dec 5, 2003 | 01:19 PM
hondaeg5's Avatar
Default h22 guys.
are any of you using hondata? what ecu are you guys using? p28,p72?
Old Dec 5, 2003 | 03:07 PM
SilverEk3dr's Avatar
Default Re: h22 guys. (hondaeg5)
P28
Old Dec 5, 2003 | 04:25 PM
hondaeg5's Avatar
Default Re: h22 guys. (SilverEk3dr)
p28 has no knock sensor right? i think i want that. p72 looks for knock correct?
Old Dec 5, 2003 | 05:29 PM
Yeah p28 doesnt look for knock
Old Dec 5, 2003 | 05:43 PM
hondaeg5's Avatar
what do you feel is better about the p28?
Old Dec 5, 2003 | 07:57 PM
It works....
I dont know. Either way its the same. I could car less cause I know my car is tuned well, and I dont have to worry about knocking. Even if you use the p72 & hook up the butterflies in the intake it wont work right cause it comes on too late for the H22 which would kill vtec some...
If I could get a p30 (del sol dohc vtec) then I would. Just to have the knock, but I couldnt get one for a steal. So **** it..
Old Dec 5, 2003 | 08:43 PM
hondaeg5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr &raquo;</TD></TR><TR><TD CLASS="quote"> Even if you use the p72 & hook up the butterflies in the intake it wont work right cause it comes on too late for the H22 which would kill vtec some...
more info on this
Old Dec 6, 2003 | 05:48 AM
I cant remember exactly, but I know that the butterflies wont open at the right time anyway. So its gonna mess with vtec changeover & everything.
Just save some money & get the p28
Old Dec 6, 2003 | 06:55 AM
hondaeg5's Avatar
will the p28 control the iab's?
Old Dec 6, 2003 | 09:26 AM
No the p28 has nothing to control the IAB.
IMO the IAB's are over-rated. If you really think about it. When you race someone your gonna launch at like what 4000 or so. The IAB's will be about ready to open then anyway. So I would just take them out & not worry about it, or hook up a vacuum line to the iab control, and leave it alone. That way it would open at WOT.
Old Dec 6, 2003 | 04:13 PM
Newman's Avatar
New User
P28 w/S200 setup. Running modified Type S settings and it runs great. No IAB settings on it but we removed the butterfly stack from the intake manifold so top end power feels really good. I've given a couple of other HT members the same program that I'm running and they said they like it alot on their H22A Civics.
Old Dec 7, 2003 | 10:24 AM
se93's Avatar
Default Re: h22 guys. (Newman)
Dave:
Check your email.
Old Dec 7, 2003 | 10:52 AM
Newman's Avatar
New User
Default Re: h22 guys. (se93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by se93 &raquo;</TD></TR><TR><TD CLASS="quote">Dave:
Check your email.</TD></TR></TABLE>
Gotcha back
Old Dec 7, 2003 | 12:30 PM
hondaeg5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">P28 w/S200 setup. Running modified Type S settings and it runs great. No IAB settings on it but we removed the butterfly stack from the intake manifold so top end power feels really good. I've given a couple of other HT members the same program that I'm running and they said they like it alot on their H22A Civics.</TD></TR></TABLE>
can you give me more info on the removal of the iab's? are you a hondata dealer?
Old Dec 7, 2003 | 06:49 PM
If I was you I would just unplug the little vacuum actuator on the side of the intake, and just leave it be.
Old Dec 7, 2003 | 11:14 PM
jacobyb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr &raquo;</TD></TR><TR><TD CLASS="quote">P28 </TD></TR></TABLE>
Old Dec 8, 2003 | 04:34 PM
slamed93si's Avatar
Default Re: h22 guys. (jacobyb)
dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr
Old Dec 8, 2003 | 05:59 PM
hondaeg5's Avatar
Default Re: h22 guys. (slamed93si)
[QUOTE=slamed93si]dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr [/QUOTE
that may be good for me
Old Dec 8, 2003 | 06:41 PM
how often do you race below 4k rpm? It wont even matter. From what I understand its like 3ft/lbs of torque lost. You wont even notice.
Old Dec 8, 2003 | 06:48 PM
goforbroke's Avatar
MEAT PATTY
I recall looking at a dyno chart somewhere that with the p72 you will lose some bottom end power but gain top end power. And with the p28 will have more bottom end power but lose a little power up top compared to the p72.
Old Dec 8, 2003 | 07:05 PM
hondaeg5's Avatar
Default Re: h22 guys. (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">I recall looking at a dyno chart somewhere that with the p72 you will lose some bottom end power but gain top end power. And with the p28 will have more bottom end power but lose a little power up top compared to the p72.</TD></TR></TABLE>
yea thats what im thinking. i have pleanty of bottom end power. maybee ill get both! lol.
Old Dec 8, 2003 | 07:07 PM
hondaeg5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverEk3dr &raquo;</TD></TR><TR><TD CLASS="quote">how often do you race below 4k rpm? It wont even matter. From what I understand its like 3ft/lbs of torque lost. You wont even notice.
im going to try it with the line disconnected and see how it feels.(daily driveability)
Old Dec 8, 2003 | 08:02 PM
Jason kiDD's Avatar
Are we gonna dyno next year mang.. I want to see some numbers from some different setups when it gets back warm.. hehe
Old Dec 10, 2003 | 03:20 AM
hondaeg5's Avatar
Default Re: h22 guys. (Jason kiDD)
oh hell yea. i wanted to do it this year.
Old Dec 10, 2003 | 07:09 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg5 &raquo;</TD></TR><TR><TD CLASS="quote">
can you give me more info on the removal of the iab's? are you a hondata dealer?</TD></TR></TABLE>
Just take apart the intake manifold and remove the butteryfly stack and put it back together. Better for top end performance. Not an official Hondata dealer but I have a Stage 4B and have all of the stock base programs from the CD (older version) and can load those and modify them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamed93si &raquo;</TD></TR><TR><TD CLASS="quote">dont u lose torque when u take the buterflys out i think u do cause my friend has a gsr and he took them out and he said that it feels like it has less torque im not sure if its the same on h22 as it is with gsr </TD></TR></TABLE>
Sure, you lose some low end torque, but on a H22A motor in a lighter Civic chassis, it's almost negligible and not even noticable. Maybe so on a 1.8L but not on the 2.2
