OBD2 distributor
Old Nov 30, 2003 | 09:45 PM
HONDADNA's Avatar
Default OBD2 distributor
Has anyone ever or known of anyone that have converted an OBD2 distributor to an OBD1? And does it work find without any problems? A friend of my mind was asking me if it would work. I total him no due to the sensors inside are different.
But was woundering if I'm right.
Old Nov 30, 2003 | 10:10 PM
aw1234dude's Avatar
Default Re: OBD2 distributor (HONDADNA)
I have a 97 civic hatch with a OBD1 b16A2 in it. I used the stock OBD2 harness that came on the car on the motor. To make the harness work with the OBD1 distributor I cut off the OBD1 plug from the b16 harness and soldered it into the stock 97 harness. The car works totally fine. As long as you wire it up correctly you should have no problems. I had to look through a couple pinouts and chiltons wiring diagrams to figure out which colored wires matched up to eachother. Some say that all they had to do was match colors but I had almost entirely different colored wires for my plugs.
Old Nov 30, 2003 | 10:40 PM
HONDADNA's Avatar
Default Re: OBD2 distributor (aw1234dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aw1234dude &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 civic hatch with a OBD1 b16A2 in it. I used the stock OBD2 harness that came on the car on the motor. To make the harness work with the OBD1 distributor I cut off the OBD1 plug from the b16 harness and soldered it into the stock 97 harness. The car works totally fine. As long as you wire it up correctly you should have no problems. I had to look through a couple pinouts and chiltons wiring diagrams to figure out which colored wires matched up to eachother. Some say that all they had to do was match colors but I had almost entirely different colored wires for my plugs. </TD></TR></TABLE>
Are you using OBD1 ecu or OBD2 ecu?
Old Dec 1, 2003 | 10:37 AM
vtecb20coupe's Avatar
B A N N E D
obd1 ecu if he's converted the dizzy wiring to obd1
Old Dec 1, 2003 | 01:39 PM
aw1234dude's Avatar
Default Re: OBD2 distributor (vtecb20coupe)
Yeah I bought a kenji OBD2 to OBD1 conversion harness and converted the stock 97 harness to OBD1 to use the ecu that came with the swap.
Bee16hatch
Aug 4, 2016 08:38 PM
civic00_dude
Sep 15, 2008 07:43 AM
Patrickchampagne2006
Mar 21, 2007 02:35 PM
DIYMIKE
Feb 23, 2007 09:06 PM
slksol
May 11, 2003 06:44 PM
