B20Vtec fuel pressure
Old Dec 5, 2003 | 12:21 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default B20Vtec fuel pressure
i want to know what fule presure you guys are running. my friend has that set up adn its reading 36-38psi and is running the stock 99 si ECU and is throwing a code 45. if i raise the fuel pressure couldnt it get rid of it? i want to see if he can go that way b 4 swaping to a P28
Old Dec 6, 2003 | 08:22 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: B20Vtec fuel pressure (cbpro)
ill tell him to get a regulator!
Old Dec 6, 2003 | 10:27 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yea i had the same thoughts about running a P28 with the convert harness with a custom set up for it kuz its throwing a code 45 right now
Old Dec 9, 2003 | 12:32 PM
Blaze45's Avatar
Brrraaaap!
Default Re: B20Vtec fuel pressure (SnoFlake EG)
Your prolly running waaaaay lean. Check your plugs and see what they tell you. Bump your fuel pressure up to 45psi. I have my B20 no tec @ 43 right now... Runs alot better then at 38....
Good Luck
Blaze
Old Dec 9, 2003 | 09:00 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: B20Vtec fuel pressure (Blaze45)
i just cehck out the car and its at 38psi but hte car is throwing a code 45 which is rich in fuel? this doesnt make sence
Old Dec 14, 2003 | 06:50 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
up'ed the pressure to 45psi and no light...lets see if it works!
Old Dec 16, 2003 | 01:23 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
been 2 days and no check light...i got rid of the code!...but still need to get a P28 to tune the car its really lacking in power
Old Dec 16, 2003 | 05:43 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
thats all up to the owner im just here to guide him i say the same thing chipped or S-AFC
djtsmith007
Nov 7, 2007 04:10 PM
OBDII Integra
Mar 9, 2005 03:17 PM
95hatchfire
Jan 12, 2005 10:52 AM
2oh6civic
Mar 12, 2003 06:30 PM
B00ST2nR
Oct 22, 2002 12:25 AM
