Which throttle cable? EG, B18C5
Old Dec 3, 2003 | 05:32 PM
Bnjmn's Avatar
Default Which throttle cable? EG, B18C5
Car = 1992 Civic CX
Engine = B18C block/head, ITR intake manifold, ITR throttle body.
I tried the ITR cable- it works only if I mount the throttle cable bracket on the far driver's side of the manifold- I'm going to have to make a brace to it doesn't move around.
What throttle cable fits correctly in this swap?
The stock cable wasn't usable at all.
Old Dec 4, 2003 | 02:42 PM
egsleepercivic's Avatar
ITR or B16 from del sol
Old Dec 4, 2003 | 02:43 PM
Bnjmn's Avatar
Default Re: (egsleepercivic)
Thanks, someone must've lied about the throttle cable they sold me, probably the same person that lied about the rear tranny bracket that didn't fit. Oh well.
Old Dec 4, 2003 | 05:38 PM
Newman's Avatar
New User
Default Re: Which throttle cable? EG, B18C5 (Bnjmn)
HCP throttle cable bracket. Works on the LS/B16A/Type R manifolds (B-series) so you can still use your existing Civic throttle cable w/out having to hack something up or to get a new throttle cable and run it through the firewall again.
Old Dec 5, 2003 | 08:09 PM
EGtoDC2's Avatar
Default Re: (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, someone must've lied about the throttle cable they sold me, probably the same person that lied about the rear tranny bracket that didn't fit. Oh well. </TD></TR></TABLE>
you sound like you're having the same luck as me with idiot previous owners. I found out today that my *incorrect* throttle cable is held on with twisty ties (or tie wraps, whatever). I could also use some help with picking the correct throttle cable==&gt; 1992 Civic Hatch DX + B18B engine swap..
Old Dec 6, 2003 | 08:44 AM
myhatchrips's Avatar
all you need is a type-r throttle bracket to hold the cable in place. 8 bucks at the dealer
Eghatchgsr8
Oct 11, 2014 03:09 PM
bleakdragonmage
Feb 25, 2007 10:40 AM
boostincoupe
Feb 17, 2007 04:41 PM
SIReg9
Oct 9, 2003 08:16 PM
BodyKits NW
Aug 29, 2003 11:59 AM
