whick axles for hybrid replacement?? HELP PLEASE
I know you can mix-and-match parts from the b-series motors, but I just need this particular question cleared up for me thanks. I need to replace my axles. I have a 95 civic with a b18c5 swap. I have access to some axles off a 99 civic si! will they work on my car with the motor I have ? How about the intermediate shaft? I know this sounds stupid, but just bear with me. I just need to replace axles correct. Intermediate shaft is does not have to change!!
Re: whick axles for hybrid replacement?? HELP PLEASE (turkdog)
yes..
all b-series axles are the SAME except the JDM ITR axles that comes with a outer 36mm. but the si one will work, just look at the axles, they're the same thing
Re: whick axles for hybrid replacement?? HELP PLEASE (pennies_hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pennies_hatchie »</TD></TR><TR><TD CLASS="quote">all b-series axles are the SAME except the JDM ITR axles that comes with a outer 36mm.</TD></TR></TABLE>
Actually that isn't true. There is a difference between the 90-93 Integra's and the 94-01 Integra's and 99-00 Civic Si. On the 90-93's, the intermediate shaft has a female end so the driver's side axles has an inner male joint like the outer joint. The 94-01 Integra and the 99-00 Civic Si have an intermediate shaft that has a male end so the outer joint is male and the inner joint is female.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turkdog »</TD></TR><TR><TD CLASS="quote">I have a 95 civic with a b18c5 swap. I have access to some axles off a 99 civic si! will they work on my car with the motor I have ? How about the intermediate shaft?</TD></TR></TABLE>
You can use both axles and the intermediate shaft from the 99 Civic Si.
