Need an honest answer quick!
Old Nov 27, 2003 | 02:35 PM
Passaudi1.8t's Avatar
New User
Default Need an honest answer quick!
Alright, I just found out yesterday that the motor in my GSR is FUBAR, so I'm not going to waste the money and downtime on rebuilding it. I really don't have that much money right now so I'm just going with a first gen B16 since they are cheap and have potential for down the road when funds are available. My question is... since most of the first gen B16's are obd0, what do I need to make this work properly in my obd1 GSR? If I swap the injectors, clips and harnesses, and the distributor, alternator, etc, will I be all set? I'll also be running an obd1 chipped p28 ecu so no need for the GSR ecu. I talked to Steve at hmotorsonline, he said I'll be fine if I just run the components off my GSR motor on the B16, but I want to make absolutely sure that it's the truth. Thanks a lot guys, I need to know real soon.
_______
Old Nov 27, 2003 | 03:41 PM
Silverhatch's Avatar
Default Re: Need an honest answer quick! (Dr.FeelgooDC2)
whats gone in you motor ? the block or the head ? ?? If the block why not just replace it..
Old Nov 27, 2003 | 03:55 PM
VTECVillain's Avatar
Just transfer all of the OBD1 GSR components onto the B16 and you'll be fine.
Old Nov 27, 2003 | 04:50 PM
k. slater's Avatar
yes, steve is right you can just switch all the stuff over.
Domani99
15
Sep 15, 2011 09:19 PM
sho_shane
Texas -OK -LA (Sales)
Feb 27, 2010 04:26 AM
3gsi
Aug 6, 2005 05:09 PM
Passaudi1.8t
Dec 1, 2003 05:55 AM
Passaudi1.8t
Nov 27, 2003 08:26 PM
