Do I really need to get a new throttle cable?
Old Nov 26, 2003 | 03:42 PM
Se-rv-Tak's Avatar
Default Do I really need to get a new throttle cable?
I have a 97 DX, and im going with the b-series swap. Do I really need to get a new throttle cable, or can I just keep my stock DX?f
Old Nov 26, 2003 | 05:01 PM
ISawUL00k's Avatar
Default Re: Do I really need to get a new throttle cable? (Soon2B18Boost)
Yes. u have to get a B-series cable.
Old Nov 26, 2003 | 05:53 PM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (ISawUL00k)
Well I hear people using their stock cable.
Old Nov 26, 2003 | 05:59 PM
ISawUL00k's Avatar
never hurts to try if it reaches use it
Old Nov 26, 2003 | 06:11 PM
MaxSterling's Avatar
use dx cable.
Old Nov 26, 2003 | 06:40 PM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (MaxSterling)
are u experienced in this matter maxsterling? did you do a b-series swap into a dx?
Old Nov 26, 2003 | 09:08 PM
Thagreybomber's Avatar
I'm using my ex cable on my b18c
Old Nov 26, 2003 | 11:06 PM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k &raquo;</TD></TR><TR><TD CLASS="quote">Yes. u have to get a B-series cable. </TD></TR></TABLE>BULLSHIT! Just make a bracket so it idles fine and gets a full sweep. But if you do get a new one it is a 2 minute job to put it in.
Old Nov 27, 2003 | 04:55 AM
VTECVillain's Avatar
The problem with the DX/CX/LX EK cable is that it is super long. The EX and HX can be reused and if you really wanted to I guess you could rig the DX one on there but.... It's not like a throttle cable is very expensive, we're talking about $20 here not something that'll break the bank. Using the proper throttle cable not only looks cleaner but is less likely to stick and will function properly.
Old Nov 27, 2003 | 06:48 AM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (VTECVillain)
True. Thanx for your response's and thoughts guys. Im just going to fork over some $20 and get me a new one. Just in case.
Old Nov 27, 2003 | 06:57 AM
Se-rv-Tak's Avatar
it doesn't matter what b-series linkage correct?
it can be from an LS/GSR/SI/ etc. etc.?
Old Nov 27, 2003 | 07:32 AM
do not get a gsr linkage
Old Nov 27, 2003 | 08:10 AM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (EF9_SiR)
im not getting a linkage. Im getting a throttle cable
Old Nov 27, 2003 | 11:46 AM
Cynical 1's Avatar
You can use the car's original cable. It is longer, but will work.
Or, just buy a B-series cable...
Me, I used my stock cable, and had no problems...
Old Nov 27, 2003 | 12:16 PM
Default Re: Do I really need to get a new throttle cable? (Revolveu2)
I think a lot of you guys have EG's and swapped in a B series and used the original throttle cable. There's a big difference between the EG base models and an EK base model. The EK's that have the D16Y7 have a super long throttle cable that loops to the front then back onto an upright throttle body. I'm not saying it won't work, but it's way easier to get the proper matching B series cable for the motor.
Old Nov 28, 2003 | 04:29 AM
Se-rv-Tak's Avatar
Ya that's what I was thinking as well. Because my TB is pointed straight up, instead of side ways. Im sure the EX is much different then mine.
Old Nov 28, 2003 | 08:03 AM
ddong2lee's Avatar
im using my EX cable with my gsr swap...
its A LOT longer...i actually didnt make a bracket for it...i just made a knot near the end so its shorter...dont really recommend it cuz its not reliable...
just a temporary solution till i get my new cable...
Old Nov 29, 2003 | 10:34 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Do I really need to get a new throttle cable? (ddong2lee)
good info
Old Nov 29, 2003 | 10:50 AM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (BLUE EH3)
you knotted the throttle cable? how did you do that?
Old Nov 29, 2003 | 12:00 PM
ddong2lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">you knotted the throttle cable? how did you do that? </TD></TR></TABLE>
u just knot it...and make sure its real tight...i dont recommend it...but if u have to, then its a simple way to go...
Old Nov 29, 2003 | 12:05 PM
Se-rv-Tak's Avatar
ill just spend $25 and get a new one from honda/acura
Old Nov 29, 2003 | 12:07 PM
ddong2lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">ill just spend $25 and get a new one from honda/acura</TD></TR></TABLE>
yea...best way to go..
needed to get the swap done so thats just the way we did it...
it works!!
Old Nov 29, 2003 | 12:26 PM
Se-rv-Tak's Avatar
kool deal man. thanx.
Old Nov 30, 2003 | 11:53 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">It doesnt matter what b series linkage corect?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost &raquo;</TD></TR><TR><TD CLASS="quote">im not getting a linkage. Im getting a throttle cable</TD></TR></TABLE>
wow, no wonder people were confused.
Old Nov 30, 2003 | 12:01 PM
Se-rv-Tak's Avatar
Default Re: Do I really need to get a new throttle cable? (LsVtec92Hatch)
lol.... wow didn't even notice that. Thanx ... my bad ...
