HELP PLEASE!!! idle problems....
Old Dec 5, 2003 | 09:50 PM
its WANG yoO's Avatar
Default HELP PLEASE!!! idle problems....
96 Spec R swap in my 00' integra LS...throwing no codes!!!someone please tell me everything this could be...my car is idling at 2000-2500rpm's...until i come to a COMPLETE stop then it idles down to 1500...and sometimes it doesn't move from 2000-2500 rpm's...i changed the TPS sensor alittle while ago...and i was told it was suppose to be set centered between the bolts...what is the proper way to calibrate it? if i unplug the TPS when the car is idling at 2500...it idles down to like 1500... what else could be the problem?
if i unplug the IACV the car idles at like 500...i can't bleed my coolant system cuz there isn't a bleed screw on the thermostat housing on this motor...also..the car idles fine with a obd2-1 jumper and an obd1 ecu...why is that? the motor is also missing a throttle body gasket...will the stock p75 ecu make it idle high with the R motor?
someone PLEASE HELP!!!
Old Dec 6, 2003 | 07:05 AM
Default Re: HELP PLEASE!!! idle problems.... (inJDMtegra)
someone?
Old Dec 6, 2003 | 07:14 AM
H23vtecEG's Avatar
vacum leak or you forgot to plug the idle sensor
Old Dec 6, 2003 | 07:28 AM
Default Re: HELP PLEASE!!! idle problems.... (H23vtecEG)
where the hell is the idle sensor? and its not a vacuum leak..there are only 3 vacuum lines...and all are hooked up...there is one vacuum line on the back of the IManifold...it usually runs to the charcoal box...but LS's don't have that on the manifold...so i just plugged that line.................
Old Dec 7, 2003 | 08:35 AM
anyone?
Old Dec 7, 2003 | 04:44 PM
WeeMan's Avatar
From: Put it in..Take it out... Put it in..Take it out, United States
bump
Old Dec 8, 2003 | 05:58 AM
hondalvr's Avatar
Default Re: HELP PLEASE!!! idle problems.... (EGizzleC1)
biggity bump
prjctwhteg
Nov 16, 2009 10:56 AM
OneFastGsr
Oct 8, 2003 08:30 AM
Vp Special K
Apr 4, 2003 09:14 PM
92TypeR
Sep 26, 2002 12:17 AM
