Rust rust rust....
Old Dec 2, 2003 | 04:06 PM
maxxd97's Avatar
Default Rust rust rust....
I'm about to order a JDM B16a for my 92 Civic CX. I have concerns about the rust in the engine compartment. The car sat for many years and rusted, quite badly. I am very afraid to even take the wheel off to look at the bolts for the suspension.
Is there anything I can do before hand to loosen up the rust on the bolts? I really don't want any headaches when I perform the swap, but I'm sure by the look of this mess I have, I'll be getting my bottle of Advil!
I'll take pics of the engine as soon as I dig out my car! (12" of snow!)
Old Dec 2, 2003 | 05:12 PM
Dan GSR's Avatar
Default Re: Rust rust rust.... (B18CFyghterCivic)
let is soak in PB blaster
then heat up the bolt with a propane torch to kill the rust
Old Dec 2, 2003 | 05:27 PM
VTECVillain's Avatar
Default Re: Rust rust rust.... (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">let is soak in PB blaster
then heat up the bolt with a propane torch to kill the rust</TD></TR></TABLE>
I've used that method quite a few times with very good success.
Old Dec 2, 2003 | 06:27 PM
eastbay92cx's Avatar
Default Re: Rust rust rust.... (VTECVillain)
Not to jump in on someone else's advice but just to clear it up so you know, heat up the nuts / bolts and loosen them while they're hot. Unless DanGSR didn't mean to do it that way, but it works for me..
Old Dec 2, 2003 | 07:23 PM
maxxd97's Avatar
Default Re: Rust rust rust.... (eastbay92cx)
Thanks for all the advice! Hopefully I will not have too much trouble!!
Prudz_lude
Feb 23, 2008 10:06 PM
jbell
Jan 6, 2005 10:55 AM
Matgallis
Aug 25, 2004 02:36 PM
TRD MA70
14
Feb 20, 2004 09:14 AM
david90
Dec 2, 2003 06:42 AM
