set-up for gsr.....????
Old Nov 30, 2003 | 04:39 PM
dohcdelsol's Avatar
Default set-up for gsr.....????
Swapping out the d16 for a gsr....What Intake, Intake manifold, Header/exhaust manifold, ehxahust is everyone running (basically the breathing route for ur engine). And any numbers of gains or losses if u have them. Thanks
Old Nov 30, 2003 | 06:14 PM
Denis Si's Avatar
Default Re: set-up for gsr.....???? (dohcdelsol)
just got my engine and would like to know that too
I know one thing for sure in that gsr intake monifold has go to go.....
Old Nov 30, 2003 | 07:23 PM
eyeamvic's Avatar
When I did the swap from d16 to b18c, I replaced the intake manifold, header, and intake. As far as gains, I wouldn't know considering my b18c was never in it's stock form. But if you don't wire up the stock intake mani, you're gonna lose about 10lbs of torque. Just save the headache and make more power and go with the skunk2.
Old Nov 30, 2003 | 07:37 PM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">Swapping out the d16 for a gsr....What Intake, Intake manifold, Header/exhaust manifold, ehxahust is everyone running (basically the breathing route for ur engine). And any numbers of gains or losses if u have them. Thanks</TD></TR></TABLE>
skunk2 intake manifold, jdm 4-1 header, rs*r original/apex n1 these are all good partrs to start with. for numbers do a search.
Old Nov 30, 2003 | 11:01 PM
Dathan's Avatar
go for HKS exhaust Hiper, skunk2 IM(get the one for b16), DC stainless headers, skunk2 valve springs and retainers. intakes are not that big of a deal a stock itr airbox will do you good and an erics racing throttle body
Old Dec 1, 2003 | 12:41 AM
eyeamvic's Avatar
Why are you telling him to get the skunk2 IM for the b16 when it doesn't fit on the p72 head? They have the intak mani for the gsr for a reason.
When I did the swap I went with a skunk2 intake mani, aem cai, and jdm dc 4-1 header. My next plan is to do custom 2.5" piping.
Old Dec 1, 2003 | 12:43 AM
ErikDaGenErik's Avatar
Default Re: (eyeamvic)
get a skunk2 manifold for sure. don't be cheap with the boltons. get race headers, full catback 2.5in piping w/no cat medrel bent, and ITR aem cai. you'll be more than happy.
Old Dec 1, 2003 | 10:22 AM
TotalJDM.com's Avatar
Default Re: (ErikDaGenErik)
The Skunk2 would probably be your best bet at the moment!
Old Dec 1, 2003 | 02:53 PM
TwoRedEGgs's Avatar
Default Re: (TotalBoost)
I would go with a ITR JDM 4-1, car sound cat, some exhaust about 2.5in, then get an ITR 3in AEM, Skunk2 mani, Hondata intake mani gasket, 01 ITR cams.
That would be a safe set up good for about 175 ish to the wheels, maybe more u never know. Now you will also probably want to get a new ECU and get it chipped and Run Hondata. The GSR ECU is a dual runner, and the skunk 2 is a single, aslo do NOT get the one for the B16, the heads are different ( to who ever said that ) get the one for the GSR only. If money is not an option then you can hit me up for another set up that will but you well over 2 to the wheels and a smile on your face !!
Old Dec 1, 2003 | 04:14 PM
ISawUL00k's Avatar
that all costs alot. if i where you i would use the stock GSR manifold but lose the waffer, cut it out....or see if it will go together without it. i run a 3" ITR cold air. i Get a 4-1 header make sure piping is atleast like 1"1/2 basically big. id say
170hp or so.. ull be more than happy GL
Old Dec 1, 2003 | 05:38 PM
mrchris386's Avatar
Default Re: set-up for gsr.....???? (ISawUL00k)
does anyone know what the best intake manifold is for a b16? im thinking of installing a port & polished edelbrock intake manifold.
Old Dec 2, 2003 | 04:40 PM
ISawUL00k's Avatar
Default Re: set-up for gsr.....???? (mrchris386)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchris386 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know what the best intake manifold is for a b16? im thinking of installing a port & polished edelbrock intake manifold.</TD></TR></TABLE>
DEL SOL B16a2 manifold
Old Dec 2, 2003 | 08:29 PM
eyeamvic's Avatar
Skunk2 intake mani for all motor.
Edelbrock for boost.
Old Dec 7, 2003 | 08:14 PM
WangChung's Avatar
whatever you do, dont forget to swap out ur muffler bearrings. seriously bro.
Old Dec 8, 2003 | 08:15 PM
ISawUL00k's Avatar
Default Re: (WangChung)
and blinker fluid.
Old Dec 8, 2003 | 08:23 PM
WangChung's Avatar
Default Re: (ISawUL00k)
for real. and cross drilled brake lines, just for good measure.
macDelli
Feb 19, 2009 08:41 PM
hispanic panic
Jul 14, 2008 02:57 PM
Slowass4dr
16
Aug 19, 2004 04:55 PM
azncollegeguy
Jan 26, 2004 06:52 AM
gsr98vtec
Dec 4, 2001 09:39 PM
