WTF, cant figure this thang out
Hi, i have a 96 civic ex coupe and i recently put in a b18c1. the motor is a 98 and so is the ECU, the only code i get is 54 which is the crankshaft speed fluctuator. whatever that does. Anyway. Its is a 2 wire sensor, and there are 2 wires that go into the ecu for the sensor. the middle plug, slots one and two. Now, do i just need to make sure that these 2 wires just make it to the sensor? I think the wires might be wrong. The stock EX motor had a 3 wire plug for the sensor and my new motor has a 2 wire. so i know i had to take out one. which i have, and got a new plug to match. But how do i know im getting the right wires to the sensor from the ECU? anyonw got a clue??
Re: WTF, cant figure this thang out (stehigs321)
well, i have a 98 gsr in my 2000 coupe ex. i just cut the 2 wires from my harness to lengthen it and connected it to the CKP located by the alternator pulley. if you have a 96, your wire harness should already have the CKP sensor on it.
So you are saying that the original EX motor has a 3 Wire CKF? Are you sure that you have the right sensor? Can you take some pics?
Re: WTF, cant figure this thang out (VTECVillain)
Yes, that is what i said. My 96 EX motor has a 3 wire CKF sensor and my 99 gsr motor has a 2 wire CKF sensor. What do i do??
Re: WTF, cant figure this thang out (HXMan)
I dont know if i wired it correctly. What color are the wires that go to the CKF sensor on an engine harness for a 96 civic EX?? I have 3 wires and one i dont use. WHat are the wire colors so i can find them. then make sure i wire them.
stehigs321
13
11-29-2003 04:02 PM
