What o2 should I get?
Right now I have a univeral O2 sensor on my DX... it is wired up to my existing wiring harness... when I get an o2 sensor, which should I get if im going CRVtec?
Re: What o2 should I get? (Soon2B18Boost)
Most OBD1 and newer Honda/Acura ECU's run a standard 4 wire O2 sensor, of course there are some exceptions: VX, CX, OBB0 1 wire, etc. Chances are that the ECU you will be using will require a 4 wire O2 which you can use from near any Honda/Acura or even an aftermarket one of that type. Neither the OBD style nor the primary/secondary of the sensor affect which one you can use, only the type (4 wire, 1 wire, etc.) to match what the ECU looks for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon2B18Boost »</TD></TR><TR><TD CLASS="quote">ok. so replace my stock DX obd2 o2 sensor with a b16 obd1 o2 sensor?</TD></TR></TABLE>
It shouldn't be necesarry to switch since they should both be 4 wire O2's, either one will work.
Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic »</TD></TR><TR><TD CLASS="quote">I don't think the dx is a 4 wire o2. Aren't the 4 wire o2's only on the VTEC equipped engines? You're gonna need the 4 wire o2 though for sure.</TD></TR></TABLE>
The DX uses a 4 wire O2. Basically from 92-95 Civic's, the only O2's that weren't 4 wire were the VX and CX. The 96-00 Civic's all had 4 wire O2's except the HX. Most OBD0 all use single wire O2's.
