OBD2 LS into a 90 CRX DX
Okay, i need help with the wiring thing. What kinda harness will i need to buy or what kinda modifications will i need to make to the stock harness to make this work? All help is appreciated. and if anyone has done this and has pics that would be even better
Re: OBD2 LS into a 90 CRX DX (capbyrd)
ditch the obd2 engine harness, use your original harness.
then u can either use obd0 ecu and distributor, or use a obd-2 distributor with preferably a obd1 ecu using a jumper.
I have a 96 B18B1 in my 91 CRX DX. You will need to reuse your stock engine harness and rewire from DPFI to MPFI which is not as hard as some people make it out to be. I used all OBD0 components to make things easier: 91 Integra LS PR4 ECU + distributor, 90 CRX Si fuel injectors + resistor box and a 94 Integra GSR alternator (OBD1 is same as OBD0 plug style).
I used a 92 YS1 GSR cable tranny and HASport mounts and shift linkage. The car was originally an auto so I has to wire around the interlock and wire up the reverse lights. Other than that it was pretty much a straight forward swap.
nitroracer
09-09-2006 07:50 PM
