Rear tranny bracket question- EG/LS swap
Help we my pennies
i got a 90-93 LS w/99si trans, i am pretty sure that i am correct but they me ask again. i need mounts any 94-00 teg. AND hows does the rear bracket bolt on. does and one have any pics?
Re: Rear tranny bracket question- EG/LS swap (BLUE EH3)
I dont have a pic but you need a 94-01 integra rear engine bracket. It has 2 bolts that go in from the diver side and then one bolt at the top that goes in from the other side. Once you put it up next to the motor you will see how it goes on. Very easy.
You will need to use a 94-01 Integra driver's side mount and mount bracket. Also a 94-01 Integra rear mount bracket. The upper tranny mount can be stock EG or 94-01 Integra. The lower front tranny bracket needs to be 94-01 Integra. If you want A/C you'll need a Del Sol VTEC bracket, if it's just for a dampening mount then 94-01 Integra will be fine.
