coilover question????
Old Nov 27, 2003 | 08:42 PM
ProjectSi's Avatar
Default coilover question????
ok I was wondering if the suspension of a 88 CRX Si (shocks and coilovers) would bolt to any 6th gen civics (including the Si)
thanks fellas any feedback would be sweet
Projectsi
Old Nov 28, 2003 | 04:43 AM
VTECVillain's Avatar
Default Re: coilover question???? (ProjectSi)
Yes and no - Yes if you use all the pieces I mention here, No if you have just the struts and coilovers. Assuming that the 88 CRX has the stock 88 rear LCA's: The 88's have the JDM style rear LCA's where the strut mounts through the center of the arm rather than the forked design (89+) that bolts over the arm. You could use the complete LCA and rear struts and coilovers on the 92+ Civic's.
Ok now for the fronts: The 88-91 Civic/CRX has a smaller diameter strut so the diameter of the opening on the strut fork is smaller. In order to mount the strut onto the newer 92+ Civic then you will need the 88-91 Civic/CRX strut for as well.
SloCrxDx91
Jan 1, 2006 12:22 PM
down_the_hatch
Nov 2, 2004 02:13 AM
96ej805
Jul 12, 2004 11:18 PM
Yellow Dragon
Jul 7, 2003 12:13 PM
