fixing header dents???
Old Dec 3, 2003 | 08:07 PM
Big Bang's Avatar
Default fixing header dents???
so i'v got the good ole gsr in my crx and of course i managed to nail thr header at some point. any way to fix it or is it time to buy a new one. BTW it's a DC 4-2-1 is it makes a difference
Old Dec 4, 2003 | 05:36 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: fixing header dents??? (The Converted)
you can have that part cut and rewelded but you may as well shoot for a used dc or something. just look around for a deal on one.
Old Dec 4, 2003 | 07:16 AM
JDMCRX's Avatar
Default Re: fixing header dents??? (vtecb20coupe)
For dents take a nut and tack weld it in two spots then thread a bolt in it and heat the spot up and pull the dent down either with arm power or a dent puller works wonders
Old Dec 4, 2003 | 07:11 PM
91tegrals's Avatar
damn thats a good idea jdm never would have thought of that..
Old Dec 5, 2003 | 04:29 AM
VTECVillain's Avatar
Default Re: fixing header dents??? (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">For dents take a nut and tack weld it in two spots then thread a bolt in it and heat the spot up and pull the dent down either with arm power or a dent puller works wonders</TD></TR></TABLE>
This does work in most cases. If the dent is too bad to fix this way, chances are that section would need cut out and replaced.
Old Dec 7, 2003 | 07:28 PM
smokey2.0's Avatar
Default Re: fixing header dents??? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
This does work in most cases. If the dent is too bad to fix this way, chances are that section would need cut out and replaced.</TD></TR></TABLE>
that's what i need to do to mine, i was quoted $100 to do it!
HXvtec
11
May 11, 2006 12:22 PM
}-Black-Ls-Stunna-{
Apr 28, 2006 02:52 PM
exploder101
Jun 4, 2005 03:44 PM
ckyguy
Oct 25, 2004 12:22 PM
sinfultrends
Sep 29, 2004 06:19 AM
