went from lsvtec to crvtec help
Old Nov 28, 2003 | 12:11 AM
gaydm.accord's Avatar
Default went from lsvtec to crvtec help
ok i have both motors out did it last night ok this morning i go and take the ls block parts off and throw em on the b20 now theres a few differences on the ls block ill have pics up tomorrow, but here are the few things i noticed....
theres a black canister on the block for oil
an oil sensor with the shaft about 2 inches long into the block(was not plugged in with ls vtec)
an extra sensor with two pins sticking out
my question is, will i be using the canister when the b20 has no place to put it into,
the oil sensor was never plugged in what is it? and would i need it?
the extra sensor with two pins sticking out my brother broke yesterday im not sure wahht its called someone help so that i can go buy another one.
sorry its not detailed but if i have pics youd know, ill have pics up tomorrow because i do not have hte usb cable on me. thanks in advance.
update:
broken prong and oil sensor slot i didnt take a pic of the sensor itself but if you need ill show you a pic it was never plugged in though
and heres the can
Modified by gaydm.accord at 9:17 PM 11/28/2003
Old Nov 28, 2003 | 11:17 AM
Combustion Contraption's Avatar
ok that canister is most likely your charcoal canister and is not for oil, its for emission purposes. and this broken sensor, what color?
what kind of vehicle is this going into? i know in 92-95 civics the charcoal can. is on the firewall. more info, so we can help you out.
Old Nov 28, 2003 | 11:36 AM
sorry bout that its going into an ek. and the sensor thats not in use is green and that other one that is broke is chrome with two prongs sticking out
Old Nov 28, 2003 | 12:15 PM
pics up
Old Nov 28, 2003 | 02:42 PM
Jaker's Avatar
Default Re: went from lsvtec to crvtec help (gaydm.accord)
The green 2 prong sensor is the radiator fan switch. Did the LS/Vtec come out of the EK? In the 1st gen B motors, the fan switch was in the back of the block like yours, but the 2nd and newer generations had that switch in the thermostat neck on the front of the block, and the sensor looks different.
The oil pressure switch is an on/off switch, and all it does is turn on the dummy light on the dash if your oil pressure gets too low. Put it back in and wire it up. It could save your motor.
The black can on the block is the oil seperator can. It takes crankcase pressure, and seperates some of the oil vapour from it before passing the crankcase pressure into the intake manifold through the PCV valve. The B20 doesn't have this can. It vents the crankcase pressure through the oil passages in the head and out through the valve cover. That is where the PCV is on a B20. You'll have to get creative, and find a way to mount the can on the firewall, plug the big *** hole, and plumb it up like the factory intended.
Old Nov 28, 2003 | 07:39 PM
jaker is correct
Old Nov 28, 2003 | 08:06 PM
that means the oil seperator can is a must? and would i have to make my own hole on the block? because there is also a hole going straight into the ls block(b18a1) so being that this is from ls block could i use original oil seperater can thats already on the ek firewall(i think thats what it is, anyone have pics or diagram on this also
can anyone show me or direct me to a wiring diagram for the oil pressure switch(there was never a plug also).
and for the 2 prong sensor the radiator fan switch i could just cut the two clips that go onto the prong and wire it up to the back of another sensor?(male side going into female on thermostat housing)
for now i will be using search button to find out how other b20vtec's have done theres
Old Nov 29, 2003 | 02:03 AM
ReeH!'s Avatar
try this site out it showed me how to do the pvc when i did my b20 swap
http://honda.hybrids.jp
http://www.c-speedracing.com/h...shtml
krysted9354
Dec 28, 2008 12:43 PM
BlUAc
Jan 27, 2006 06:39 AM
oemDC2
Apr 28, 2004 09:37 PM
oemDC2
Apr 28, 2004 09:19 PM
infamousALLMTR
Apr 15, 2002 02:36 PM
