Searching for WORDS of Wisdom, Experience, Comfort/Consolation, etc. etc.
Sorry 4the double post, not 2sure where this fits-IN
fully ported and polished GSR Head with complete Ferrea valvetrain, stainless-steel valves, springs, and retainers... stock gsr cams & adjustable sprockets... JG Victor X manifold and throttle body... ARP head studs and Mr. Gasket's MLS head gasket... type-r ecu...
...i can no longer just walk by this day after day just stockpiling parts for my DARTb20 bottom-end &... i was wondering if there'd be a valve clearance, possible bent valve issue if i where to go ahead and mate the head to my stock b20b bottom-end **** has been going so good 4me lately... i'd hate 2 now.
AGAIN, Searching for WORDS of Wisdom, Experience, Comfort/Consolation, etc. etc. & BIGup -tech fam! Thankx in advance.
Modified by Mulan at 9:12 PM 12/1/2003
Re: Searching for WORDS of Wisdom, Experience, Comfort/Consolation, etc. etc. (Mulan)
i knew i'd 4get something... the head came off an old LS/Vtec setup i had so the oil line's there, oil passage tapped in the head and welded shut, and already purchased Full Race's LSVtec head dowels.
Check this out : Some good readings and do a lot of searching. There are a lot of posts on ls/vtec or crvtec. Good luck!
nice
in one of the import tuners a guy used a old head gasket put some putty on the dome of the piston (just a little) mated the head put the belt on and gave a full rotation. i thought i was kinda funny but it worked. seem logical. he didnt torque the head sence the gaskets been crushed it should be perfect.
is the head milled? probably is but if it is less than .003 ull be fine. see alot of gsr heads mated to b20's GL
U sound like me i hated looking at my motor on the ground in pecies, but was afraid to watch my motor die even thought its been built right..
Id suggest taking to a pro if your that worried. Dont take some internet kids advice.
dantamparacer
08-01-2011 09:34 PM
S4gasm
01-17-2010 07:07 AM
Mulan
12-03-2003 12:19 PM
